Picking up a '99 C43 Thursday
2005 Porsche 911 Turbo & 2018 Tacoma TRD Pro
I'm lucky to have both a set of 17" and 18" Monos. The 18" are great for the looks, but the 17" give a more comfortable ride specially if the roads are rough and you are lowered. Also the 17" give better acceleration and have slightly lower unsprung weight.
Just my personal impressions and living since 10 years with a C43
Yes you will but depending on what spring pads you have, you might be able to raise the car by swapping them out.
There are five different spring pad sizes for a w202. If you put the thickest ones on itll raise your car.
I would start by checking that.
Look under and you should be able to see on top of your springs what looks like rubber circular dish. Itll have dot like notches on it. Three notches means its a #3 pad.
Last pic focus only on the last circled part of it.
Juice33 (10-03-2019)
just a heads up, a worn subframe bushings can drop your rear end a considerable amount. If youre changing springs it wouldnt be a bad idea to see the conditions of your subframe bushings too
Juice33 (10-07-2019)
#32
