Advice Needed
Old Mar 31, 2020 | 08:31 AM
speed43's Avatar
1999 C43 Amg
Advice Needed
Here's what's happening.
Turn car on it idles great.
Give it gas soft or hard it revs great, no hesitation.
I go for a ride, I step on the gas pedal half or full throttle and engine revs some but than chokes and the car goes nowhere. As the engine is choking or stalling the trans kicks in hard but car goes nowhere because engine is stalling.
I have no current or stored codes at all. I have installed a 100 percent functioning accelerator pedal sensor and maf.
Car only chokes or hasitates hard when car is in the road and I step hard on the gas. If I drive normal the engine does not hesitate or choke at all. And the trans shifts perfectly.
Could this be a fuel pump issue? I will change the pump and fuel filter if that's the problem.
Btw, I have installed/replaced within a year. Plugs, plug wires, O2 sensors, cam and crank sensors and air filters, aFe which uses no oil.
Any thoughts?
Old Mar 31, 2020 | 07:29 PM
PSB's Avatar
PSB
Sorry to hear,, I have no idea really.. But had the same issue a long time ago with a plugged Catalic converter
Old Mar 31, 2020 | 07:50 PM
speed43's Avatar
1999 C43 Amg
Thanks, I hope it's not that though.
Old Mar 31, 2020 | 09:49 PM
The_mabman_20's Avatar
Red 1995 C36
This sounds a lot like a bad throttle body. This is pseudo common on these cars and can be taken care of.
Hers an old thread I found with 1 minute of googling.
Old throttle body thread
Old Mar 31, 2020 | 10:21 PM
speed43's Avatar
1999 C43 Amg
Thanks. I did search before posting incase you like to know. What that thread describes is not my issue. My car does not break at any rpm. It will reach to full rpm with no problem driving it normally. But when I floor the pedal it will choke. Otherwise it's fine.
Old Apr 1, 2020 | 06:09 AM
DRBC43AMG's Avatar
Just wondering if the MAF is not playing up. Surprised there are no codes
Old Apr 1, 2020 | 08:43 AM
speed43's Avatar
1999 C43 Amg
I was hoping it was the maf. But I installed a working one from my black C43 and problem was still there. Than I put the maf from my white c43 the one with the problem on the black car and it runs great, no problems.
I ordered a new fuel pump and filter as both have not been replaced from what I found out from x owner. If it fixes the issue great, if not no harm...
Old Apr 1, 2020 | 01:22 PM
PJmak's Avatar
Seems a little extreme for a fuel pump issue.
I dont think the car would start at all if the fuel pump was faulty.
The fact that the car starts and idles means its getting fuel. Does the car ever not start or have a hard time starting?
GIve the car a good reset.
Disconnect the battery for at least 15 minutes and go from there. Also make sure your sparkplug wires have proper connections. Were these done recently?
Old Apr 1, 2020 | 11:42 PM
ECTurboGSX's Avatar
98 C43, 15 Alfa 4C LE, 18 Tesla Model 3 DM Perf, 08 Duc S1000, 02 Duc 998, 98 Duc 748, 01 Miata
Sounds a lot like when my MAF went bad. I also was not getting a code for the longest time and then I got P0172 I believe. But it basically felt like the car was a bit sluggish and wasn't making anywhere near 300 hp at WOT, especially once I got above 2.5k to 3k RPMs.
Old Apr 2, 2020 | 08:15 AM
speed43's Avatar
1999 C43 Amg
Yes car starts fine every time. Plugs are new and wires and coils. I will try the reset. Thanks.
speed43's Avatar
1999 C43 Amg
Maf was the first thing I replaced but did not solve the issue. Thanks.
Old Apr 3, 2020 | 06:02 AM
DRBC43AMG's Avatar
Did you use a genuine Bosch one?
Old Apr 3, 2020 | 07:58 AM
speed43's Avatar
1999 C43 Amg
I did yes.
Old Apr 3, 2020 | 09:48 AM
silverc4s's Avatar
99 C43, 73 911 targa
Symptom is like a clogged fuel filter, impeding good fuel flow.
Old Apr 3, 2020 | 10:08 AM
speed43's Avatar
1999 C43 Amg
Yes that's what it seems to be. I just received the fuel filter and pump. So will see if that fixes the problem.
Old Apr 4, 2020 | 06:28 AM
DRBC43AMG's Avatar
I believe you need to put some fuel in the new filter before connecting the lines and assembling onto the vehicle
Old Apr 4, 2020 | 08:53 AM
speed43's Avatar
1999 C43 Amg
Really? I've done the pump and filter on 3 w202s and never did this. Just finished the job last night and car turned on with no problems. Today im going to test drive see if it still chokes when I give it gas hard.
Old Apr 5, 2020 | 10:10 AM
speed43's Avatar
1999 C43 Amg
Yesterday I took the car for a drive. Problem completely solved. Running so much better even when driving normal. And now when I floor it the car goes and does not choke anymore. I changed the fuel filter which looked good. And fuel pump which looked very old.
Thanks to those that posted, really appreciate it.
