No enough torque???? What Could be the cause????
My car has no enough torque, specially at the beginning. I have replaced the spark plugs and cleaned the fuel injectors. I have even tested the fuel pump pressure and was at standrads. Air sensor is also OK. What else to be check and what do you think the cause is. Mind you, checks show no matter with the catalyzer.
