Right turn signal double timing it?
Old Sep 5, 2004 | 03:51 PM
J-98C43's Avatar
1998 C43
Question Right turn signal double timing it?
So when I cut on my right turn signle it does a double fast blink. Like one of the bulbs is burned out. The strange thing is that both of the bulbs are just fine. I've even swaped them out just in case there was something screwy going on. Any ideas? I'm thinking the relay maybe but I can't figure out which one it is. Can't find a diagram in my owners manual.
Any suggestions?
Old Sep 11, 2004 | 05:16 PM
J-98C43's Avatar
1998 C43
The dealer shows no relay for the turn signals. How can that be? They certainly are not running enought voltage for the lights through the stalk.
Anyone have any info here?
Old Sep 11, 2004 | 07:21 PM
scorchie's Avatar
GL320CDI / C63 Edition 507 Coupe (EDP) / E63 S (on order) / G500 / Smart Brabus
If you're sure all your indicator bulbs are good, then it could be your driver side SAM or the EIS. Does your horn work? Or your wipers? If so, then the CAN communication is good for your turn signal stalk.
-s-
Old Sep 12, 2004 | 12:50 AM
pointman's Avatar
a car that can't do the throttle reset.
there is corrosion on the contacts on one of the lights,. clean all contacts and it will be fine.
