Power side bolsters not working...
1998 C43
![Unhappy](https://mbworld.org/forums/images/icons/icon9.gif)
Has anyone fixed this problem that can tell me what's involved. This seems to be a fairly common issue. Both of the C43's that I've driven have had it. None of the 4 seat (2 in each car) has had a working power side bolster. I can hear the pump run, but it sounds like a valve isn't closing or there may be a leak in the bags. Seems wierd to me that it's been so consitent in the both of the cars that I've driven. Anyone here that can lend some direction. I'd like to avoid the stealership.
Thanks!
Thanks!
2002 C230 : 2007 C230
I had this same problem awhile back & the dealer wanted $$$ to fix it. Turns out my problems was just as suspected by a forum member.
Pull the back off of your seat & you will see some air tubes and a plastic "Y" fitting. They are most likely not connected. Just plug them in and all is well until they pop off again.
1998 C43
That was it!!
Thanks KWIK. Two screws at the bottom of the back seat cover and that crazy little splitter was staring at me with one of the tubes disconnected. Next time they come loose I'll have some zip ties or clamps of some sort to prevent it from happening again.
Now for some twisties...I'll actually be able to stay in the seat now!!
Thanks again!
Thanks again!
