Any tips for replacing the flex disc?
Old Sep 10, 2021 | 01:55 PM
JohnnyRock's Avatar
1998 C43 AMG
Recently had the car aligned after lowering and the tech said both flex discs showed signs of cracking. He mentioned needing to drop the exhaust to change them out. They quoted about 2.5 hours to do the job. Anyone here tackle this DIY project?
Old Sep 10, 2021 | 03:38 PM
Sulaco's Avatar
1999 C43 AMG, 2005 E55 Wagon
Pretty sure you can do it without dropping the exhaust. I did the rear on mine.
Old Sep 10, 2021 | 09:24 PM
importfan21's Avatar
1998 C43, 2017 Honda Accord Sport
No exhaust drop needed. Just a lot of finangling.
Old Sep 11, 2021 | 06:21 AM
DRBC43AMG's Avatar
I dropped the exhaust on mine when I changed both flex discs and central support bearing. For the rear no problem with exhaust mounted. Front guess it's more difficult even if doable, but probably will take as long or more with the exhaust down.
Old Nov 2, 2021 | 06:03 PM
Sulaco's Avatar
I have now done them both without dropping exhaust. But I think it's because I have the mid-section (2ndary cats and resonator) removed on my car and replaced with pipes. Either way, I was able to get an impact wrench above the exhaust so I could very easily bust loose all the bolts on the front flex disc. It was a pretty painless job, actually.
