43 2002 w215 swap OIL PAN VERIFICATION
Old Sep 8, 2022 | 08:08 PM
WaarpSpeed's Avatar
w202 c43
Hello, does anyone know EXACTLY which is the proper oil pump to install in the w215 m113.986 5.4 engine once the upper pan from the C43 is transferred over? Common sense tells me to get a w210/w208 oil pump, since the lower oil pan on the 43 and 55 are the same.
let me know.
Old Sep 9, 2022 | 04:12 AM
DRBC43AMG's Avatar
Have you gone through this lengthy thread? Your answer may be in there, but not 100% sure though
https://mbworld.org/forums/c36-amg-c...ap-thread.html
Old Sep 9, 2022 | 09:40 AM
WaarpSpeed's Avatar
w202 c43
Yea i did, but i cant seem to find a part number for the c43/e55/clk55 oil pump.
I'll also need a diagram of how to lay the sillicone gasket.
Old Sep 10, 2022 | 07:07 AM
DRBC43AMG's Avatar
Try this:
https://nemigaparts.com/cat_spares/e...asis=20203344W
or this one:
https://www.ilcats.ru/mercedes/?func...=1&language=en
Unfortunately, private individuals no longer have access to the official MB Parts Information System, so we need to use other sources, but most are reliable.
For workshop manuals and "How to do" things, try the following link, OK you need to pay something but well worth it IMO:
https://www.emanualonline.com/?produ...SAAEgLtBPD_BwE
Last edited by DRBC43AMG; Sep 10, 2022 at 07:20 AM. Reason: Added 2nd & 3rd link and text
Old Sep 12, 2022 | 02:11 PM
x463's Avatar
1998 C43 w/ 55 swap Wavetrac LSD and 6-Speed manual
I'm pretty sure I still have the C43 oil pump from when I did the swap if you need one. My donor came from a CLK55 so I didn't have to swap the oil pump nor the upper/lower oil pans from the C43 engine. I still have the lower pan also. (Some idiot bought the upper via eBay for his V6 M112 engine and then left me bad feedback when I wouldn't take the part back and pay for return shipping.)
Old Sep 16, 2022 | 09:46 AM
WaarpSpeed's Avatar
w202 c43
Thanks ill keep you in mind, i ordered a new pump. I know the cl55 uses same chain and lower oil pan. All i need is proper guide on applying the gasket seal.
