Drive (fan) belt diagram
Old Dec 2, 2022 | 07:34 AM
Samuel Joseph's Avatar
w202 c43
I've just bought a 98 c43 and it doesn't have the drive belt on. I'd appreciate it if someone could attach a belt diagram.
Old Dec 2, 2022 | 07:58 PM
speed43's Avatar
1999 C43 Amg
Here you go. The diagram is also for our C43 cars.
https://mbworld.org/forums/c32-amg-c...t-diagram.html
Old Dec 2, 2022 | 11:43 PM
DRBC43AMG's Avatar
Now that you have the diagram (see above post from speed43), I would strongly recommend you check the wear on the pulleys before putting on a new serpentine belt. Usual culprit for excessive wear is the idler pulley #7 on the diagram and the #1 automatic belt tensioner. The idler pulley is cheap to replace, the belt tensioner a bit more. With the age of these vehicles, if these items have never been changed, it may be a good time and preventive maintenance to do so. While in there check also for possible wear on the water pump axle.
Old Dec 3, 2022 | 06:52 AM
speed43's Avatar
1999 C43 Amg
Thanks for pointing that out. I should have mention that too. Specially with what happened to me. I hit the gas pedal hard doing a test run and the belt came off the pulleys. It got shredded after it got loose. I had to remove all the bits and pieces around the water pump pulley. I thought I had it all but some tiny pieces had stayed behind the pump. This caused stress on the pump and 2 months later the water pump went bad.
Belt and water pump were replaced a few years back so they weren’t that old. So it’s far better to replace what Daniel said, well worth it.
Old Dec 4, 2022 | 05:49 AM
DRBC43AMG's Avatar
These are the different sounds one may hear when parts are wearing out: water pump and belt tensioner. Sorry didn't record the idler pulley on the top though. After installing new parts, the engine became super quite which I guess ia always nice to hear.
I guess a short video says it all
