1998 C43 w/ 55 swap Wavetrac LSD and 6-Speed manual
C43 Xenon self-leveling part #s
I've checked 6 different websites w/ EPC functionality (no longer have access to the official MB EPC unfortunately) and can find the diagram w/ the parts I need - but none of the 6 show all the part #s shown in the diagram....only parts I don't need listed.
Anybody have the actual part numbers for the lever/arm parts 32 and 38:
OR....a good online EPC that returns all the parts in the diagram! (In the real EPC you can change a filter setting to show all parts)
Thanks!
(Worse case - I can piece this together with rod ends, threaded rods, etc)
Thanks.
Don't seem to be available unfortunately.
But - the sensor (w/ a superseded part #010-542-77-17) is still available and used as recently as 2014. I'll have poke around in the EPC for new models and see if I can find something equivalent or easily modified that is available. Worse case - nothing too special about the OEM parts. Can fab something up with readily available threaded rods, rod ends, etc.
