C43 jacking points
I'm wanting to switch to my summer tires and do it myself. I see that some use a special adaptor on a floor jack to do this.
Anybody just use a normal scissor jack to change the wheels?
The independent shop that put my winters on didn't use any special adaptor but did use a floor jack.
Since I don't have a floor jack it's probably cheaper to have the shop do it but I'm a cheap Dutchman I'd rather do it myself.
Any ideas?
Then go from there. You'll see how the "Special" MB adapter fits in there but you can use your common sense to put whatever jack you have in there without damaging anything.
So is a floor jack supposed to contact what appears to be a plastic lifting point?
Also if you lift at the rear point and take it high enough, both front and rear wheels clear the ground. This made swapping my snows in and out a piece of cake!
Wowza are the P-Zero's noisy! They are noisier than my snows.
Probably unrelated to the wheel switchover, but now I have a slight pulsing on the brake pedal under braking.......
If you still feeling the brake pedal pulsing take it to your dealer for a closer inspection.
