C450/C43 AMG
3WD|DINANTRONICS Sport Performance Tuner for 3.0L Turbo Engines
Old May 1, 2017 | 04:34 PM
3WD's Avatar
3WD
SPONSOR
Car
DINANTRONICS Sport is the boost controller for the masses. Its simple design/execution allows for easy installation/removal that can be performed in a blink of an eye and yields results you will be sure to feel, and enjoy, from the get go. Coupled with Bluetooth capabilities right out of the box that allows for user controlled adjustability and a live boost monitor to keep track of the action its a value proposition that is unequaled in the marketplace. Dyno Proven Results!!!
DINANTRONICS Sport Maximum Gains: Up to40 HP, 40 lb-ft of torque.
DINANTRONICS Sport plugs into a single sensor which lends itself to a very quick and and discrete installation, or removal, should the need arise. Not only does this connection method offer a simplified install but also effectively utilizes the factory DME, in tandem with itself, in order to re-map boost, fueling, and timing for optimal performance. Once installed DINANTRONICS Sport enjoys connectivity to various smartphone devices courtesy of its built-in Bluetooth Smart system. From the free app one has the freedom to reduce stock boost for valet duties or crank up the boost all the way up to the "race" setting for maximum enjoyment… or anywhere in between. Regardless of what setting is chosen there is a power level for everyone. Also within the app the end user has access to a live boost monitor which streams boost data in real time to the phone. Not only will you be able to feel the difference but now you can see it as well!
Benefits of the DINANTRONICS Sport Performance Tuner for MB 3.0L Turbo Engines:
+ Up to +40 HP and +40 lb-ft
+ Bluetooth smart (Android and iOS Compatible)
- Live boost monitor
- Multiple power settings to choose from (Sport, Sport+, and Race).
- Valet / parental control modes (-3 PSI)
+ Quick, easy, and discrete installation
+ Automatically detects engine type and loads appropriate mapping
+ CARB EO submitted and approval is pending.
+ 14 day satisfaction guarantee
+ 1 year product warranty (does not include consequential damages or labor costs)
Product Specifications
Labor Hours/Installation Hours0.25Emission StatusCARB EO submitted and approval is pending.Max HP GainUp to 40 HPMax Torque GainUp to 40 lb-ftIncluded NotesDINANTRONICS Sport Performance Tuner
Special Note: DINANTRONICS Sport is set to the "Sport +" setting out of the box. This can be adjusted via the bluetooth app.
Compatible with:
  • 2015-17 C400
  • 2015-17 C450 AMG
  • 2016-17 AMG C43,
  • 2015-17 CLS400
  • 2015-17 E400
  • 2015-16 GL450
  • 2015 ML400
  • 2015-17 S550e
  • 2015-16 SL400
  • 2015-16 GLE400
  • 2016 GLE450 AMG
  • 2016-17 AMG E43
  • 2017 SL450
  • 2016-17 AMG SLC43
  • 2017 GLS450
  • 2016-17 AMG GLE43
  • 2016-17 GLE550e
  • 2016-17 AMG GLC43
PRICE: $299.00 Shipped
PN# D440-0035
3WD|DINANTRONICS Sport Performance Tuner for 3.0L Turbo Engines-d440-0035_1_zpsitrkrwsc.jpg
3WD|DINANTRONICS Sport Performance Tuner for 3.0L Turbo Engines-d440-0035_2_zpsgfxng9vj.jpg
3WD|DINANTRONICS Sport Performance Tuner for 3.0L Turbo Engines-d440-0035_4_zpsulwajqjd.jpg
3WD|DINANTRONICS Sport Performance Tuner for 3.0L Turbo Engines-d440-0035_3_zpsxrltsehz.jpg
3WD|DINANTRONICS Sport Performance Tuner for 3.0L Turbo Engines-d440-0035_6_zpsaauvzrqv.jpg
