Wheel spacers with factory wheels.
I would like to have my wheels closer to flush than what MB provides.
Anyone here running spacers on factor wheels?
-post pics
-what specs
Locally,a guy is selling a set of 20mm spacers. This could work fine on the rear, but I need to confirm I won't have any poke.
thanks in advance!
20's will work in the rear if lowered, otherwise 15 is borderline pushing it. I ran 5's in the front.
This is 18mm in the rear at OEM height with 19's
This is 8mm's in the rear only:
Hope this info helps.
I have a C43 with the split 5's, 19".
I'm not quite sure of the width and offset of my wheels.
Originally I was planning on replacing the wheels. They have started to grow on me. So I am waiting on some height adjustable springs, and wanting to dial in the ability to get close to flush.
thanks again!!!!
thanks again!!!!
I am a newbie here, driving 2017 W205 C300 with Original AMG multispoke wheels , fr 225x40R19 rear 255x35R19.
I always want to lower the car using Eibach Prokits, and also thinking to use eibach pro spacers to support the overall look.
Based on the above stock specs, what will be the most suitable tire size for this?
Based on my research, is it Front 225x35R19 & rear 255x30R19?
I supplied a few spacer sets with bolts to quite a few members here. The spacers I used are fully hub centric in and out, and I supplied them with the properly matched length lug bolts.
The biggest issue I have seen people here have is with the spacers, many of the suppliers have a radius off the hub section that is the biggest culprit of vibration as the wheel hub ends up not seating all the way to the pad, this and also suppliers that do the bore at 66.6 rather than actually 66.56. It is a hair I know, but I have seen these circumstances cause the vibration issues, but I have never seen a problem with the R12 bolt replacing an R14.
I think this was good for you to bring up and thanks for pointing this out, I am sure everyone here appreciates that this was addressed as doing these spacer upgrades can sometimes be complicated, and where I come from in my experience starting back in 1993 working for Lorinser/CEC early in my career, then to Brabus for many years, and most recently I was the last official importer for Carlsson, all specializing in Tuning Mercedes-Benz Vehicles, and I have always said, if it is not right or tested and proven, don't do it. Unfortunately there are a lot of people here that get burned, and I hate seeing people spend good money after bad, so please don't think that I would ever mention someone to do something that would compromise their safety and function of their vehicle.
Again thank you for bringing this up.
Also, the C450/C43 also came with lower offset wheels, so the spacers for that setup also used the 10mm/12mm.
The 12mm/15mm combo was ideal for the 19" multi spoke sport wheels.
With the 18" wheels the 10mm/12mm spacers will provide the more aggressive stance and will not pose any issues.
The pictured extended R12 bolts are made, as I'm sure you know, by Bimecc (Italy). The part numbers are S17D40 (40mm bolts for 12mm spacers) and S17D45 (45mm bolts for 15mm spacers). The correct for MB wheels R14 bolts, also made by Bimecc, are: S17D40R14 and S17D43R14 respectively. (Bimecc of course makes bolts for Audi/VW OEM wheels as well, those part ## end with R13 instead of R14 for MB). Just because someone uses R12, does not make it correct/safe. You can visually see that it does not seat correctly, hence clamping force is compromised.
As far as the official RAD importer, are you referring to Otis LA Inc? He is the only major supplier in the US I am aware of who is carrying correct R14 bolts, so if R12 is just as "safe" why carry a large R14 inventory?
Again, it is good that you raised this question and I don't see any reason to argue your point, and this again is great knowledge for members here to get the right comfort when making these modifications, if the R14's are not available at the time, just don't do it if you don't feel using the R12 is right, even in the case where Phil would say it is, people can be in the know either way.
No hard feelings!
No hard feelings!
17mm Rear
12mm Front
-post pics
-what specs
thanks in advance!
All of our c43 products are in stock and on sale now!
https://modalwork.com/collections/wheel-spacers
