C450/C43 AMG
Sedan wheel spacers
Old Dec 26, 2017 | 10:26 AM
Nc43's Avatar
2018 C43 Sedan
Sedan wheel spacers
Morning gents...hope you all had a wonderful Christmas.
Have any of you done wheel spacers on your sedan? If so, what did you go with? I’ve seen a few of you with coupes go 15mm in the front and 20mm in the back however, not sure if the sedan would be the same. I would prefer to go DRM vs DR series (DRM bolts spacer to hub and then wheel to spacer vs using longer lugnuts) however, these start at 20mm. Thus, I was thinking 20mm in front and 25mm in back (based on stock setup it definitely feels like the back sets further in thus, should come out more) however, not sure if this will be too much? My setup is factory 19” wheels, lowered on H&R Sport Springs. Thanks in advance...
Old Dec 26, 2017 | 11:30 AM
CClement's Avatar
2009 C230
15mm up front and 20mm in the rear is a pretty nice flush setup on the sedan.
Old Dec 27, 2017 | 08:33 PM
Dieseldan9's Avatar
2018 C43 AMG Brilliant Blue Metallic
On stock 19s correct?
What r your thoughts on 18s?
Old Dec 27, 2017 | 09:17 PM
CClement's Avatar
2009 C230
Ya that is stock 19s. I'm not 100% sure on the 18s.
