C43 Coupe vs Sedan weight
I was checking out the MBUSA website and I found that they state on the specs:
Coupe 3,968 lbs
Sedan 3,759 lbs
Does anyone know why a couple would weigh 200 lbs more than a sedan that has more doors?
Coupe 3,968 lbs
Sedan 3,759 lbs
IIRC, the coupe shares cabrio DNA, meaning it has additional weight from additional structural rigidity in place for the cabrio. No roof means the chassis flexes a lot so additional bracing is required elsewhere in the car.
But, someone will correct me if I am wrong.
The cab weighs even more than the coupe even with th soft top. The extra reinforcements used on cabs to counter flex doesn't exist in coupes in general. From all the posts I've read the coupe weighs more than the sedan because of the panoramic glass roof
AMG C43 3LV6 (10-29-2020)
Is the sedan faster than the coupe? Apologies if the answer is obvious.
AMG C43 3LV6 (10-30-2020)
Received 2,200 Likes
PFL205.064
W205 2016 C300 4Matic *SOLD* 2017 C43 AMG COUPE
PFL205.064
Interesting, thank you for your insight, is it because the difference between sedan vs coupe? The coupe have steel but regular C sedan have aluminum doors?
I think it’s for safety reasons because the coupe is overall a smaller car with no additional pillar like a sedan has between doors
PFL205.064
