just replaced rear brake pads, now it makes LOUD noise.
i just replaced rear brake pads from dealer, now when i brake, it makes those LOUD noises once in a awhile; those LOUD noise like semi-trailer trucks make when they brake.
is this normal? i never have this noises before the brake job.
also, do brake pads come in pair? on my order sheet invoice, it only listed Qty 1 for TS Disk Brake pad at 125.44$
Brake pads are normally sold as a set, 1=1 set. The noise could be a simple as the pads need to be broken-in, heat shield hitting the rotor, not applying brake lube to the back of the pad or a bigger problem. It's hard to tell without seeing/hearing it. Do about 5 hard stops from 80 to 5 mph back to back, drive for another 5-10 minutes to cool them down, if the noise still there, take it back to the dealer.
netboy (01-12-2018)
Just went to dealer this morning. they test drive the car, then i test drive the car, it not making any noises. so i go home.
then in the evening, when i go shopping and when i driving home, it making those noise again "once it a while" when i brake. dont know what causing it.
