C450/C43 AMG
C43 Sport + auto mdoe cutting out
Old Feb 6, 2018 | 05:29 PM
Trappers's Avatar
Mercedes C43
I have a 2017 C43 which when in Sport and Sport + auto mode is redlining between second gear and third gear and then it cuts out on the limiter as if you had hit the redline in manual mode.
Old Feb 6, 2018 | 06:26 PM
Gungaslow's Avatar
2017 C43 sedan
Is your car stock or tuned? Any power mods or performance exhaust?
Old Feb 6, 2018 | 10:30 PM
DRLC43's Avatar
C43 Cab
sounds like a warranty issue, unless you have had a Tune, then it is a tuner issue. Probably needs a software up date.
Old Feb 6, 2018 | 10:56 PM
Gungaslow's Avatar
2017 C43 sedan
It could be the performance exhaust valve being stuck closed also.. is there any codes ?
Old Feb 6, 2018 | 10:59 PM
DRLC43's Avatar
C43 Cab
Curious, why would that cause it to hit the red line limiter?
Old Feb 7, 2018 | 12:41 AM
sean1.8t's Avatar
c-fo-fiddy
Your trolling has never been clever but it's not even funny anymore. I mean, PE? Really?
Old Feb 7, 2018 | 07:34 AM
hlieberg's Avatar
2018 AMG C43 T
If I understand the question correctly, I think it's the ASR/ESP which does this? I have the same problem, but never a problem when I turn off the ASR/ESP. With the ESP-system activated the power is reduced sometimes when accelerating hard in Sport+ and shifting from 2nd to 3rd. I see it more often in winter, because of less grip with the winter tyres, but I've also experienced it with summer tyres and dry asphalt.
Old Feb 19, 2020 | 02:32 PM
Petje's Avatar
W205 C400
Any update on this one?
have the same thing ?
Old Feb 21, 2020 | 05:36 PM
18bora's Avatar
2020 GLC 63
Possibly it's a transmission issue. Either the transmission is reaching a torque limit, or it's too cold (not up to operating temp yet) causing a lag in shifting... hitting redline/rev-limiter before it's able to shift.
