C450/C43 AMG
Exhaust tips -Night Package
Old Feb 7, 2018 | 04:24 PM
CClement's Avatar
2009 C230
Hey everyone, not sure if anyone is looking but I have a set of exhaust tips that are
the black chrome from the night package. They are almost brand new. PM me if anyone is looking.
Thanks.
Old Feb 8, 2018 | 02:36 PM
CClement's Avatar
2009 C230
Old Feb 8, 2018 | 05:14 PM
Joe Doan's Avatar
Mercedes C43
Exhaust tips
Hi,
are the tips tips still available? If so, what are you asking for them? Where are you located?
thanks
Jor
QUOTE=CClement;7376147]Hey everyone, not sure if anyone is looking but I have a set of exhaust tips that are
Thanks.[/QUOTE]
Old Feb 8, 2018 | 05:31 PM
CClement's Avatar
2009 C230
Still available, PM me.
Old Feb 8, 2018 | 07:02 PM
Joe Doan's Avatar
Mercedes C43
Exhaust tips
Will you do $200
text me, much easier.
647 919-1458
Thanks.
Old Feb 14, 2018 | 01:25 AM
karthik's Avatar
2018 C43 AMG
I'm looking to get the chrome ones myself - are you by any chance swapping the black ones out and putting in the chrome ones? I'm looking to find out if the dealer is my only option to get the Chrome ones...
Old Feb 14, 2018 | 10:24 AM
CClement's Avatar
2009 C230
No, I did a C63 diffuser/tip swap.
These are sold btw. Thanks!
Old May 1, 2018 | 10:22 PM
ikaikaclassic's Avatar
2017 C43 AMG coupe
If you don't mind me asking- Where did you get these from?
Old May 1, 2018 | 10:25 PM
CClement's Avatar
2009 C230
My dealership.
Old May 2, 2018 | 12:25 AM
bulldogsrule's Avatar
C43 CAB
How did you remove the tips?
Old May 2, 2018 | 07:44 AM
CClement's Avatar
2009 C230
They are just bolt-on, very easy.
Old May 2, 2018 | 12:31 PM
DougsC43's Avatar
2018 AMG C43
CClement,
Per bulldogsrule question, can you give specifics on removal. I also have the night package on a new '18 C43 and wanted the chrome tips to stand out against the diffuser. I purchased to swap out. I removed the two 40 Torx bolts, and nylon bolt brackets. They push toward the front of the car to release to two top tabs, but then what? There does not seem to be enough room to rotate down and off behind the diffuse under the car, and the tabs seem to want to hang up trying to bring them out the back of the car - diffuser. I did not force and buttoned back up and try to find the answer. Thank you in advance for any help / directions!
Doug
Old May 2, 2018 | 04:56 PM
CClement's Avatar
2009 C230
I had the bumper off when the exhaust tips were removed. They bolt to the bumper, the exhaust pipes sit loose inside them. I think they have to slide forward to remove from valance panel.
I really can't recall as my bodyshop guy did most of the dirty work but watching him seemed fairy straight forward. Was quick to do. Try messaging Joe Doan on this post, he
purchased them from me and swapped them out easily from what I recall without removing the bumper.
Old May 3, 2018 | 05:28 PM
nonblkcanadian's Avatar
2018 C43 Coupe
let's seee that :P
Old May 3, 2018 | 06:22 PM
CClement's Avatar
2009 C230
Old May 6, 2018 | 08:37 AM
W205C43AMGCoupe's Avatar
2017 AMG c43 coupe
Once you remove the screws from the nylon brackets you can wiggle the tips out from the rear of the car. You need to slightly pull open the opening around the tips and slowly slide one side under and then the other. The two latches on top of the exhaust tips tend to catch so you need to ensure they slide under the lip bracket attached to the bumper. To reinstall them it, it has to come from the front of the bumper and the exhaust pipes need to be dropped so you have room to reinstall them. Or you could just remove the rear bumper and insert them.
