C43 Offset
https://www.tyreleader.co.uk/alloy-w...x112-82-936199
https://www.tyreleader.co.uk/alloy-wheels-brands/bbs/ci-r-670/8.5x19-et45-5x112-82-936282
https://www.tyreleader.co.uk/alloy-w...x112-82-936282
225 is better suited to a 8" rim width and 235 is better suited to an 8.5" rim width, this is for 19" tires and aspect ratio range of 35 to 40.
8.5J 30ET front
9.5J 40ET rear
225 40 19 will work on 8.5J
255 35 19 will work on 9.5J
If you get the above rim spec, you can upsize to 235 and 265 respectively as well.
This fitment should be very good.
I was wondering if you could help me with choosing the right set of wheels for my car. I have a C450 4MATIC. The car is currently on the factory 18 Inch wheels. It is lowered(on coilovers I guess but not entirely sure, because I've bought it this way and I haven't had the chance to ask the previous owner of the vehicle).
The wheels I'm thinking of going with are HAXER HX04F:
19/8.5J/ET40 FRONT
19/9.5J/ET40 REAR
For tires I'm probably going to get 225/40/19 FRONT and 255/35/19 REAR.
My question is would it be a problem to fit these wheels with these tires on the car?
Thanks in advance!
