C450/C43 AMG
Engine Cold, Still Crank It?
Old Jul 17, 2018 | 01:45 AM
FirstMBAMG's Avatar
C43 AMG Coupe
If the engine is cold, by engine standards not winter weather, do you still crank it in sport+ at a light? Or wait til the oil to heat up?
Old Jul 17, 2018 | 02:40 AM
zibby43's Avatar
'20 GLC300 SUV
Always, always wait until the fluids get up to temperature (i.e., the temperature readings turn from "blue" to "white") before you start to flog the car.
You want to make sure warm oil has made its way to all the critical parts. Warm-up doesn't take too long on this platform; especially with respect to the oil temperature.
Best way to warm up the car quickly is by driving it. Don't let it sit around an idle. Manual backs that up as well. Hope that helps.
Old Jul 17, 2018 | 02:55 AM
waisoserious's Avatar
GLC43, X P100D, S P100D, CT200H
Of course you wait for the oil to warm up. What kind of question is this? Warmer fluids flow more freely, which helps accommodate higher revs. Which is why you wait for the oils to warm up.
Old Jul 17, 2018 | 06:52 AM
Dieseldan9's Avatar
2018 C43 AMG Brilliant Blue Metallic
I wait for both the engine and transmission to come up to temp.
For me the car performs horribly when cold. IE bucking delayed performance sloppy shifts
Old Jul 17, 2018 | 08:37 AM
munis's Avatar
2021 Mercedes C63s AMG Coupe
Always turn drive in Program E and C when engine oil and tranny temps are in the blue region (70C for engine oil) and (50C) for tranny oil. After that feel free to give it some.
Be patient and love the car, and the car will love you back, literally.
Old Jul 17, 2018 | 03:26 PM
Clint Westwood's Avatar
18' C43 cab
The owners manual states power is reduced until the engine is up to temp, which I guess means blue has changed to white. By how much I dunno since I always take it easy until I see white. Racing the engine when it's cold is a good way to need a rebuild long before it should be needed. Also, idling to warm up isn't good for an engine either. Start and drive, but take it easy until it's warm.
Old Jul 17, 2018 | 05:06 PM
FirstMBAMG's Avatar
C43 AMG Coupe
its a question with a lot of useful answers, bothers me that people take time out of their day to give arrogant answers.
Old Jul 17, 2018 | 05:14 PM
HTXgearhead's Avatar
2018 C43 sedan
This forum is VERY friendly compared to other car forums out there.
Old Jul 18, 2018 | 10:27 PM
speedlaw's Avatar
C 43
My first turbo car was a Callaway VW. Probably could trade it even up for a C43 if I still had it.
The primitive system (spring wastegate, no intercooler, water injection also on a spring to control detonation, and only engine oil cooled the turbo bearings) had a sticker on the window. It said
"No Boost until Warm".
"Allow 30 seconds before shutting off engine".
I'm not nearly as absolute with a modern turbo car, but the concepts remain. Let all the parts get happy before you hammer it. Let it sit and the turbos spin down before killing the ignition.
Old Jul 19, 2018 | 09:49 AM
munis's Avatar
I never turn off the engine unless the oil temp is below 100C.
Old Jul 19, 2018 | 10:10 AM
FirstMBAMG's Avatar
C43 AMG Coupe
Great responses thank you everyone. Will go through and formally thank when I get to a PC.
Old Jul 19, 2018 | 03:52 PM
zibby43's Avatar
'20 GLC300 SUV
Mercedes uses electric oil/water pumps as well as electric fans in these engines. So, theoretically, even if you shut off the engine after WOT, the turbos are still being cooled correctly.
Of course, it doesn't hurt to take extra precautions!
