hub bore
hub bore
so after much research on wheel fitment for the C450, i found wheels that i liked from the help of a fellow member.
19x8 front, 19x9 rear.
i noticed the wheel bore on the 19x8 is only offered in a 57.1 size. the rears are 66.56, so that should be plug and play.
since i need spacers on the front, 15mm, what else do i need to make these work? do they have conversion spacers for these hub sizes?
i am confused.
EDIT: for those who had similar questions, there is no solution for this other than to have a machine shop bore out the wheel...... something i personally dont want to do.
no responses needed. but hopefully someone finds this info helpful.
i am confused.
