question about removing star emblem on trunk
has anyone removed the star emblem off the trunk or replaced it? i got a new one black one, to finish my dechroming.
i watched a few videos about people removing it but they all leave out the details.
do the little grommets that hold it in place stay mounted on the trunk or do they fall out the back once the emblem is removed?
basically i am asking to see if i need to take off the trunk and keep tabs on the grommets, so they dont just pop off and rattle inside somewhere. or if everything stays in place and its just plug and play from the outside.
thanks!
I actually used this video as a guide. Gives a good idea of what to do and how it works.
thanks!
Ive been trying to purschase one on eBay and Amazon and it keeps saying it doesn’t fit my 2019 model.
That's where I got mine, but it looks like they're down to their last set. It shows a long delivery time, but I actually got it in less than two weeks. Your results may vary.
Any of the stars that fit the 2016-2018 C-class sedan will work on a 2019. The star on the coupe and cabriolet is different. One thing I did notice, is that the star is a pretty soft plastic, and the black star that I received wasn't perfectly flush with the trunk like the OEM chrome star was. I heated it with a hair dryer and very gently bent it before I did the install. If you have the time and patience, it might be worth cutting little strips of 3M double-sided tape and putting that around the edge of the star, so it won't stick up and possible get snagged when you wash the car.
guardian, do you think heating the edges and trying to bend it slightly would give it a better fit while heating it on the car? it isn't a terrible fit as is, but it does bother me because i am a perfectionist. and you make a good point about catching an edge while cleaning or something. i wonder if a bit of heat will warp it enough to sit flush? anyone have any recommendations? i really dont want to do the process all over again in removing the badge just to get some sticky tape in there. wish i would have known that before i did anything, i definitely would have taken the time to do it.
just to update on what i tried, i took some small little cut pieces of standard double sided sticky and the stripes were so small and thin, they didn't really hold the edges of the badge to the trunk at all. so that didn't really help as much as i thought it would. it stuck for about 1 minute, then came off. i feel like the extremely minimal contact area didn't really give itself a chance to adhere.
