New 2019 Coupe Jerking/Bucking Issue
alexasa, RichardCranium3, stockbmw, jonathan358, zibby43, munis and AMGiggity are all on 2017/2018 9G-tronic transmissions that start in 2nd gear unless in Sport+, and they don't complain about jerking/bucking or rough starts in Eco/Comfort/Sport, and pay more attention to throttle application in Sport+ where it starts in 1st.
HotPotJ, evoi19, Candyman19, 3.Pointed.Czar and TModelle (me) are on 2019 9G-tronic transmissions that start in 1st gear in all modes from Comfort and up (no Eco mode) , and are all complaining about jerky starts and poor shifting even in Comfort mode.
The programming for 2017/2018 is clearly different than the 2019 models. It is no wonder that 2017/2018 owners can't agree with the points of view of the 2019 owners.
Your car should jerk and buckle like mad bull in S+. In comfort, it does every now and then while slowing down on 2nd gear, just remove your foot from the brake should ease the jerking. The engine braking is terrible on this car, uses zero torque converter which is retarded.
That would help to prevent overheating.
In my own experience with my 2019, I don't have any "bunny hopping" that has been described by others, but I find the 1st gear too short and pretty useless as it is such a "short lived" gear before 2nd comes along, seems really unnecessary to start in 1st. However, my 1st to 2nd gear shift isn't very smooth, not like a DCT kind of smooth, and I get the upshift fart no matter how light or heavy I drive the car. So the result is that moving off is overall pretty jerky for both driver and passenger.
first is too short for sure. i actually preferred my 7g in the 450. gearing was a lot more fun to manually shift through.
I can share my experience with my C63S. Not exactly the same car, but the core of the transmission is the same. After I took delivery of it in Germany, it was definitely rough around the edges. Driving around town was jerky and not very pleasant. It's exaggerated in the C63S by the fact that it uses a clutch instead of a torque converter. For the next ~6000 miles I mostly did Autobahn and country road driving. Very little city driving. It learned well how I drive on the open road, but every time I got into the city it was still jerky. Then at around 6300 miles I dropped it off for shipping to the USA. Took possession of it again late September and have now driven an additional 2500 miles on my usual roads and taken it for some canyon runs on the weekend. At first it still had the same jerkiness around town, but here I'm doing more city-like driving and it clearly learned my city/town driving style over the last 2500 miles and has gotten fairly smooth now. There's still the inherent directness in the drivetrain from the fact that it uses a clutch, so if I mishandle the throttle it will be felt as a jolt in the drivetrain, but driven normally and skilled it's very smooth. My previous car with a dual clutch transmission learned to declutch in third gear when slowly coming to a stop. Pretty much how I do with manual transmission. The C63S still downshift all the way to 2nd gear, but it does it smoother now. Of course I have learned, too, and retrained my muscle memory so that's part of it. What it doesn't do anymore now is downshift all the way to 1st gear, unless I come to a full stop for about a second. I regularly pull away in 2nd gear now after brief stops. It does the same in manual mode. I can hold it in 2nd gear and pull away instead of going down all the way to 1st.
If I can impart one thing, use the proper driving mode for the situation and give the car enough time to learn how you drive. Don't confuse it by using S+ around town sometimes and C other times. I drive in C around town, and as soon as I hit the highway or an open road I put it in I*, which I've setup like S+, except with the suspension in comfort and the transmission in manual mode. I don't like the transmission shifting on me automatically on the highway. When I hit up a really fun road like the canyons I go to, then I put it in full S+. So really I think the important thing is let it learn properly in the right mode for the right situation. If you use S+ for spirited driving as well as driving around town, then it really doesn't know how you wanna drive in S+. You are teaching it two opposite ends of the spectrum that are not really compatible with each other.
http://www.mercedesmedic.com/reset-m...-instructions/
1) Get in car and shut the door.
2) Turn car to on position (but do not start), by pressing twice on "Start" button.
3) Turn off all lights/electronics
3) Hold down gas pedal to floor.
4) Wait 20+ seconds and then turn car off by pressing the Start button once.
5) Wait 20+ seconds continuing to hold down gas pedal to floor, take foot off gas pedal and don't touch anything
6) After car system completely goes quiet (about 2+ mins), you can open the door and get out of the car.
via https://mbworld.org/forums/c-class-w...ess-start.html
At the bottom of the page in that link you posted. Don't think it will work for 2017 onwards.
"This should work on E, CLK CLS CLA ML GLK S SLK C models, Crossfire, basically any Mercedes Benz years:
1995 1996 1997 1998 1999 2000 2001 2002 2003 2004 2005 2006 2007 2008 2009 2010 2011 2012 2013 2014 2015 2016"
When I had my '18 C43, I experienced quite a bit of either sluggishness in C or intermittent surging and bucking with minor throttle input changes in lower gears in the first few months of ownership. I tried my best to keep smooth, progressive, linear inputs, but going over a hump in the intersection at a stop sign could set the transmission off in S+.
By the time I turned in the car, neither of those behaviors were as pronounced. Was it merely me adapting to the car, or something else?
