C450/C43 AMG
What's an acceptable Front:Rear % difference in diameter
Old Jul 20, 2019 | 12:57 PM
TModelle's Avatar
C190
For our AWD C43, what's an acceptable % difference in rolling diameter between front and rear axles?
2% or less maybe?
Old Jul 21, 2019 | 08:59 AM
Conv_GSDriver's Avatar
'18 Audi A4
Yes, the closest you can get to overall diameter is best. with today's sensors that 2% or less is good IMO. Going significantly heavier though while keeping same rotational mass may not be good. I believe the stock wheels are cast plus run flats, these wheel/tire combos are probably 50+ lbs at each corner easy.
Old Jul 22, 2019 | 10:14 AM
alexasa's Avatar
c
would really try to stay under 1% difference front and rear and less than 2.5% over stock (3% is usually advisable as fine but i have seen that the fenders are tight on the front axle on the front splash guards)
Old Jul 26, 2019 | 02:05 AM
xX G Xx's Avatar
Tuned '18 C43 coupe & Stock '18 GLE43 coupe
For your reference, the 18" wheels came with 225/45/18's front and 245/40/18's rear. That's a -1.2% circum difference.
19" wheels came with 225/40 & 255/35 and that's a -0.4% difference.
Seems factory went with slightly taller tires in the front. Just a coincident or design requirement? dunno...
I went with 225/40/19 & 265/35/19 and that a +0.8%.
So far, only only around 2000km, no issues.
Old Jul 26, 2019 | 07:41 AM
'18 Audi A4
I ordered mine with the stock 18s as I have an extra set of 19s I kept from my previous W204 C63. Need to see the sizes but I think it will be similar to what you described I think they're 235/265.
Old Jul 26, 2019 | 08:31 AM
TModelle's Avatar
C190
I’m thinking of doing 235/275 in 20”, 0% variation between front and rear. Just worried it’d give the car even more understeer than it already has (a lot of).
Old Jul 26, 2019 | 08:35 AM
alexasa's Avatar
c
it certainly will - although i believe negligible and maybe imperceptible in daily driving - you'll need a wider front section to combat understeer. but the upsize and better compound may neutralize this out better than anticipated
Old Jul 26, 2019 | 08:39 AM
TModelle's Avatar
C190
Yes I have been hoping that it will work out that way. Let’s see. Still hunting for something suitable. What’s the narrowest practical rim width for a 275?
Old Jul 26, 2019 | 08:49 AM
xX G Xx's Avatar
Why narrowest rim on fattest tire??
Old Jul 26, 2019 | 09:02 AM
alexasa's Avatar
c
9 inch is within spec but 275 looks perfect on a 9.5
