C450/C43 AMG
+ Paddle shifter sticking
Old Aug 18, 2019 | 07:27 PM
milleian's Avatar
GLB
I was driving my car today and my right side (+) paddle shifter became stuck after manually shifting to a new gear using the lower side of the paddle. I had to manually push it back into the resting position. I then tried shifting using the top side of the paddle and it shifted normally. On the next shift I pulled the lower side on the paddle and it stuck again. When I pull the top side of the paddle it resets the stuck shifter. I noticed there is a lot of play in the right side paddle compared to the left side paddle. My car is still under warranty but my closest dealership is over 2 hours away. Has anyone experienced this before? What was the solution?
Im trying to be as descriptive as possible. Sorry if this is confusing. Thanks in advance.
Old Aug 21, 2019 | 07:12 AM
Harold1898's Avatar
2015 E400 Coupe
Had 5 MB cars including a C63 and have never heard of this. Into the dealer I would say
Old Aug 21, 2019 | 10:27 AM
Steelguin's Avatar
2018 C43 AMG
Warranty
Old Aug 21, 2019 | 12:21 PM
RichardCranium3's Avatar
'16 AMG GTS, '21 AMG GLE53
Definitely a pain, but 3rd ring on the warranty bell. You're not required to visit Mercedes (or any manufacturer for that matter) for warranty work. It's the path of least resistance, but given your distance, it might be worth investigating a local independent shop to see if they're capable and you trust them.
Old Aug 22, 2019 | 09:39 AM
Dalle1985's Avatar
W205 AMG C63S
Sounds like something has broken in the paddle - have never experienced anything like that and I use the paddles all the time.
Old Aug 22, 2019 | 09:08 PM
Tirgoman's Avatar
2023 AMG EQE 53
If it's under warranty I wouldn't have anyone else mess with it. The steering column is complicated, leave it to the dealer.
Old Aug 22, 2019 | 11:58 PM
milleian's Avatar
GLB
Thanks for all the replies. I’m moving into Washington state in a couple of weeks so I’ll hold off until I get up there. I have enough to deal with now.
