Pop DURING Accelerating
I have a JB4 on and thing is awesome. I've noticed though every once in a while when I'm flooring it, I'll get an exhaust pop (like mid gear, not during the change or when letting off the gas).
Anyone else have this "issue"? Is it dangerous for the engine? I imagine it'll add some backpressure. What's the cause of this? Too low AFR? Timing issue?
Is it in a higher gear or lower gear? If low are you seeing wheel spin when it happens?
My guess is the car see's too much boost for the fuel/temp/elevation and is pulling back significant throttle even though you are all the way on it. But its just a guess without seeing a log.
I was thinking misfire but I imagine that would throw a code. JB4 can read DTS codes as well as fault codes correct? As far as knock, the ignition timings look OK (not fantastic).
Both times I believe it was second gear, shortly after shift change (change had been completed), pedal completely floored. Didn't notice any traction issues, and its happened with traction on and completely off (not sport).
I will post a log that looks unremarkable in my opinion of when it happened the first time (0-60 pull).
I also have some slightly weird behavior from shift change 3-4 where the engine seems to begin to rev up again after shifting, then drops revs, then starts reving again. This seems to be improving though and I think its just the ECU adapting to the new parameters. I included this info for completeness.
I plan on getting another log of it this evening and hopefully some video.
Thanks for the help guys.
If any ones wondering, the map makes fantastic power. Running about 0.7/0.8 seconds faster 0-60 without break boost. Everythings stock. Might add DP's at some point if I get some advice on how to tune for them.
If it happens again/I get a log of it I'll post.
