C450/C43 AMG
JB4 PLUS Bluetooth
Old Mar 1, 2020 | 06:21 PM
gabemcclintock's Avatar
2019 C43 AMG
JB4 PLUS Bluetooth
SOLD
Old Mar 1, 2020 | 06:23 PM
BMS's Avatar
BMS
Former Vendor of MBWorld
2018 C63 Sedan
If you're a 2019-2020 adding in the BCM will definitely will get you 11 second potential just like pre-2019 models. GLWTS.
Old Mar 1, 2020 | 06:26 PM
2019 C43 AMG
Originally Posted by BMS
If you're a 2019-2020 adding in the BCM will definitely will get you in the 11s just like pre-2019 models. Beyond that not sure what "it should" do for it. GLWTS.
They "it should" was from you guys when I asked about if it'll provide noticeable gains.
"...Should help all maps a bit including map1"
Old Mar 1, 2020 | 06:33 PM
BMS's Avatar
BMS
2018 C63 Sedan
Sounds like a standard statement.
What if more boost is more than your octane can support safely? What if you have an underlining spark plug issue that becomes exacerbated at higher boost levels? I think a better way of phrasing it is the BCM will allow you to build more boost. And in most cases more boost is a good thing. But it all depends on what you're looking to do exactly.
Old Mar 1, 2020 | 06:37 PM
2019 C43 AMG
Agreed...more boost is a good thing and I think it's safe to assume most people buying the JB4 are looking for more boost
I loved the JB4 on my 2018 which is why I kept it to instal on my 2019. But to be honest I haven't read or gotten a straight answer on whether adding the BCM will in fact give me the gains I was seeing on my 2018 until this thread.
Old Mar 1, 2020 | 06:38 PM
BMS's Avatar
BMS
2018 C63 Sedan
I see you have another thread with some sort of shifting issue so I'd work on resolving that before worrying about the BCM. Sounds like that is your major complaint at the moment?
Old Mar 1, 2020 | 06:40 PM
2019 C43 AMG
Honestly no complaints...was just trying to figure that issue out.
Old Mar 3, 2020 | 11:58 AM
Hokusai's Avatar
2017 C43
Interested. Still for sale?
