C450/C43 AMG
c43 unexpected Noise when gently applying throttle
Old Mar 17, 2020 | 11:07 PM
getsetgo's Avatar
c43
Hi All,
I recently got a c43 (2020 model) in the US. The car is super fun to drive and have been enjoying it, this being my first MB. At around 800 mile mark, on the way back from work I heard a booming noise while gently applying throttle to maintain speed. It was probably around 55 to 60mph. As soon as I let of the gas, the noise stopped. This continue for a bit and then when I switched to sport+ and then back, it seemed to go away. I then drove the car for 30 mins and didnt hear it. I then heard it again a few days later when driving during the day and it went away after a while. Then yesterday evening again on the way back form work I could hear the noise while gently applying the throttle. And it seems to reduce at higher speeds. Today morning when I drove didnt have any issues. I have seen an thread around rear diff problems here. Could this be related to it? Anything I need to look for. Can cold weather cause any problems as I see the issue more in the evenings then day times. The temperatures are not terribly cold (40 to 45 F). The noise is hard to miss now that I can see the difference between when it is there and when it is not there.
Any thoughts.
Old Mar 17, 2020 | 11:44 PM
stockbmw's Avatar
2018 C43
Originally Posted by getsetgo
Hi All,
Any thoughts.
Best to record your experience. If the noise occurs every now and then, the dealer won't do anything when you drop the car off for an inspection and noise isn't there.
If you can get multiple recordings on various days, you will have better chance.
The diff noise is like weird humming bad ground feedback from speakers at certain speed like 80kmh or 50mph. Havent heard any reoccurring booming noises.
Old Mar 18, 2020 | 01:01 AM
getsetgo's Avatar
c43
I had the same sound coming today evening when driving back. Near my home I decided to drive around the neighborhood at slower speeds to see if I can find anything with the sounds. I finally got a consistent steps: The sound seems to come at rpm between 1000 and 1500. Once it crosses that it doesn't come. I found this when I switched to manual mode. In manual mode since the revs are held higher for the lower gears consistently above 2k, I didn't hear any sound until I dropped down to 6 or 7 and the rpm dropped closer to 1500. In comfort mode it is very pronounced when I just want to keep slower speeds. Sport+ helps a bit as the rpm is a bit higher there as well. I drove around for a bit and can consistently reproduce the behavior.
Does the transmission adapt as we drive? When I leave work I drive in a parking lot at slow speeds before getting out, but when I leave from home, I hit higher speeds fairly quickly.
Any thoughts on what this could mean?
Old Mar 18, 2020 | 03:33 AM
zibby43's Avatar
'20 GLC300 SUV
What do you mean by "booming" noise?
Can you be more descriptive? Also, can you identify where the noise is coming from (general direction)?
Old Mar 18, 2020 | 08:19 PM
W205C43PFL's Avatar
Sorry that you are experiencing such an issue with a brand new vehicle. I am also not sure what do you mean by booming sound, does it sound like firework or a cannon?
Come to think of it, I recently heard a new noise when gently applying throttle too (2017 C43), but the noise only happens between gears (so after it shifts, it makes the noise and then immediately disappears) It happens when slowly accelerating in Eco Mode and Comfort Mode and the sound is most noticeable when engine shifts between 1500 RPM and 2000 RPM. In between gear 2 to gear 3 and then in between gear 4 to gear 5. Sound is not present at all when the engine shifts higher than 2000 RPM.
Since OP's noise is constant even after gear shifts, the sound I am experiencing might be something totally different.
I can't really describe the sound I am experiencing either, but it sounded like something coming from the exhaust more than a transmission or maybe ... *I'm just hearing it wrong* and that the sound is from a completely different location so transmission can not be ruled out. But it really didn't sound like it is coming from the front of the vehicle. Initially thought it was the wastegate but then realized the sound is completely different to what was posted on this forum. The sound ONLY appears when the vehicle is warm.
The closest I can refer to the sound is a slight mechanical scratching sound (this description might not be close to accurate at all).
I am wondering if anyone have an idea or speculation based on this limited information I provided? I wouldn't be able to get this checked as my winters are still on and on top of that, COVID-19, mb dealerships are closed.
Old Mar 19, 2020 | 01:17 AM
getsetgo's Avatar
c43
I think I found what the problem was. On highways I was usually driving on sport+, but one day I drove in Comfort mode as I read during the breakin they recommended driving in C. So thats when I noticed this sound. After my experiments last two days, I realize that the sound is the one that happens when trying accelerate in a gear above where I should. What was happening is that in Comfort mode since we get to 9th pretty quick, when you barely apply throttle, the gear doesnt drop down to increase the revs. I barely put any pressure on the throttle so transmission doesnt change the gear. But if I press it a bit more, it drops down to the right gear and revs go up. So in 9th if the revs stay below 1500 this happens. Or even for a few other gears. So today I went for a ride and figured out the correct pressure to ensure that transmission recognizes that I am trying to accelerate.
In sport+ mode, since gears are aggressive, this wasnt an issue. In manual this wasnt a problem and when In 9th I dropped to 8th when I wanted to accelerate a bit. Its possible in comfort mode in slower speeds while driving around the neighborhood I probably didnt hear the sound as I usually have a bit louder music. After driving in manual, I feel like 7 gears gave an optimal experience versus the 9.
So is this something I need to check out as I drove this way in the incorrect gear only two or three times?
In the drive today I finally got a very good feel for the car and gearing and back to enjoying the drive.
Old Mar 19, 2020 | 04:06 AM
jonathan358's Avatar
2018 Mercedes C43 AMG Coupe
I highly doubt that you are getting the right diagnosis. Go get it checked out at a dealership!
Old Mar 19, 2020 | 04:39 AM
Harold1898's Avatar
2015 E400 Coupe
This why the cars have warranty and MB has service technicians. Take it in, even if they can't hear it they will record the issue and test drive it. Get them to give you a report in writing.
Old Mar 19, 2020 | 07:59 AM
TModelle's Avatar
C190
I really don’t understand what you mean about the sound and rpm/gear selection - I can’t fathom what kind of sound that could be. How about auto mode. If you drove in auto mode would the gear be wrong and you get the sound too?
Old Mar 19, 2020 | 11:03 AM
stockbmw's Avatar
2018 C43
Could you record the booming noise?
Old Mar 19, 2020 | 11:12 AM
alexasa's Avatar
c
probably back pressure noise when low rpm and turbo not being fed enough air
Old Mar 19, 2020 | 05:30 PM
W205C43PFL's Avatar
Not sure if you are talking to OP or me but if you were talking to me.. The transmission was always in auto mode.
I never mention the gear being wrong so likely you are talking to OP and not me. If that's the case just ignore me lol.
Old Mar 19, 2020 | 07:33 PM
getsetgo's Avatar
c43
I might have used the wrong choice of word to describe the sound "Booming" and I guess that was misleading. So apologies for that. I would equate it to the sound that you hear when there is a wheel bearing issue but not as intense. I also talked to the dealer and explained and would take it in once the covid situation settles down a bit.
I have a family car which is a Audi q5 and havent driven it for a while since getting the c43. So today I decided to drive that and check the rpm/throttle response. It doesnt have any sport packages. I drove it and got to the same rpm range (1500-1750) and when I gently apply the pressure to just keep the speed, i heard the same sound, just a little fainter. The q5 is 8 speed. So it seems like the throttle sensitivity on the comfort mode doesnt down shift fast enough when bare minimum pressure is applied to keep the vehicle in constant speed. Sport+ gears stay lower so rpms are mostly close to 2000. In comfort I either need to apply throttle a bit higher or I use paddle to down shift and then the sound disappears.
It could also be the back pressure noise that alexasa mentioned. Since I have the PE I pay more attention to how things sound and thats why I noticed this.
I havent been into the technical details of cars for a while until I researched c43 and buying it. So I am just trying to learning these things as well. One video I saw about low rpm/ lugging and also LSPI was interesting.
At this point a I am sticking mostly to drive it on sport+ or manual. The fuel economy might be down, but I guess I didnt buy c43 for the fuel economy
Old Jul 18, 2022 | 03:04 PM
Merl86's Avatar
C43AMG
do you know what issue the 2017 had as I have the same in my 2017! Thank you
Old Jul 18, 2022 | 04:47 PM
W205C43PFL's Avatar
Sorry to hear about that, do you have a video clip on this? I don't think I have the sound anymore on my vehicle so that was strange. To add to the confusion (which is awkward since I was the one that mentioned about the sound in the post you quoted), I don't even remember what I was hearing back in 2020.
Old Jul 18, 2022 | 05:02 PM
Merl86's Avatar
C43AMG
Car is at Mercedes at the moment and I took shoo foreman for a ride this morning to show it… he said it is the rear differential..
3 weeks ago we replaced bad engine mounts and check trans mounts… it’s only when applying gas very light. Happens in C,S and S+…
you can feel and hear it very easy when sitting in the car.
File Type: mov
Old Jul 18, 2022 | 05:48 PM
W205C43PFL's Avatar
If it is the rear diff, yes then it is very common I got mine replaced a couple of times on my 2017.
https://mbworld.org/forums/c450-c43-...-thoughts.html
Old Jul 18, 2022 | 07:07 PM
GermanCarShow's Avatar
2017 C43, 1966 230SL, 2006 Jeep Rubicon
@Merl86 Thanks for posting that video!!! Now I know what to listen for. Sounds like a bass guitar strumming over and over. I can understand why a few people described it as booming.
Old Jul 18, 2022 | 07:34 PM
Merl86's Avatar
C43AMG
every time I apply gas slightly it makes that sound… I’ll update everyone once MB gets back to me on the exact issue and solution. I have the extended warranty so hope it’s covered
Old Jul 22, 2022 | 08:22 AM
Merl86's Avatar
C43AMG
car is at Mercedes’ and they are replacing rear diff under warranty…
Old Nov 9, 2022 | 01:42 AM
PeteC43's Avatar
C43 W205
have same issue with mine. Mercedes Sydney are replacing the diff. Need to wait 4 weeks as it apparently needs to come from Germany
I get a faint whine when applying gads at 50mph and above
Old Nov 9, 2022 | 07:08 AM
W205C43PFL's Avatar
Yes it is indeed very common:
https://mbworld.org/forums/c450-c43-...bration-i.html
Edit: Here are some more:
https://mbworld.org/forums/c450-c43-...ise-issue.html
https://mbworld.org/forums/c450-c43-...igh-speed.html
As you can tell if the rear differential isn't the only one that fixes your problem, the driveshaft might be something you want to look at next.
Edit 2: not C 43, C 300 actually this time: https://mbworld.org/forums/c-class-w...ml#post7104051
Old Oct 8, 2023 | 05:21 AM
Nissu79's Avatar
C43 AMG W205
Weird sound gearing on low RPM
I have C43 Amg W205 year 2020 and same sound appears when I'm shifting 4 to 5th gear at low rpm. Noise disappears when I accelerate harder on higher rpm. And it also does it only with warm engine / transmission.
It's weird as it is there and then it's not ...🧐
Please let me know if you figure out where your sound came from ?
Old Oct 8, 2023 | 08:21 AM
W205C43PFL's Avatar
@Nissu79 Were you able to get the sound on camera because I wasn't able to, my mic (tried a couple different ones) just didn't pick it up. If you were somehow able to get the sound on camera, we might be able to figure it out for you (assuming your sound is different to what I used to have as I never figured out that one myself but if your sound is something I came across before I might be able to help you out).
As strange for me however, it disappeared, now I am getting a ticking sound when the transmission upshifts, here are some videos https://drive.google.com/drive/folde...P81fC7xyyG15Wt and a whining sound when shifting from Park to Drive or Park to Reverse, it sounds similar/or exact to the sound you put the vehicle in Park, does your vehicle also makes this noise when you put in Park? It is the Parking pawl and the mechanism engaging right? Here is that video (you can hear both the tick sound when shifting to Park and the whining when shifting from Park to Drive and Park to Reverse https://drive.google.com/file/d/1Mi4...PIW6bJhyK/view
Back to your sound, does it happen only when it is dry and not humid conditions like the sound I previously experienced back in 2020 or so? If you have any idea of what is the sound I am experiencing as well, please do comment, thanks! Sorry that you posted and I ended up asking you for help as well. Hopefully you can capture your sound on camera and I can help you figure it out as well.
Old Oct 8, 2023 | 01:20 PM
Nissu79's Avatar
C43 AMG W205
Thanks for replying.
Humidity does not make difference. I have absolutely no idea what does...well it usually doesn't appear when transmission is cold but when it gets approx. 60 C it starts. And even then sometimes it doesn't appear.
Yeah I did capture it to my camera today...sound is not very clear but can be heard.
I tried to upload it but I am so ****ty to use these platforms 😓
Anyway if I manage to upload file the sound starts around 5 second from beginning.
I tried to listen your footage...both of them but I didn't catch any weird ticking noice. Maybe I just don't know what to listen 😕
File Type: mov
