C450 turning of after the start/stop
I would check the following
1. start stop system by turning it off completely from the battery by disconnecting the aux battery wire on the negative terminal
2. check the voltage of your battery or bring into a local parts store and have your battery tested
3. Make a memo how your car starts each time. How long it cranks before starting. Might be issue with your starter.
Imo, doing #1 should fix your problem but start/stop eco will no longer work.
