No hotspot in 2020 C43?
Hi all, I've got a 2020 C43 that is basically fully loaded. I'm about to do a long road trip and wanted to setup the wifi hotspot for the car for my girlfriend to use while I drive. ATT let me create an account through their connected car portal for unlimited data. Unfortunately, when I try to activate the hotspot in the Connected settings menu there isn't an option -- just a check box for wifi. If I click it, it either tells me it is connecting or disconnecting the wifi. The internet status shows it is connected. I called MB and was eventually told that my vehicle "module" does not have hardware compatability for hotspots. Is this true? I find it hard to believe that a 2020 Mercedes that is otherwise connected and has a car modem (plus some random WiFi option) is incapable of functioning as a hotspot. Any one else ran into this or am I missing something? Thanks a ton- Dave
Received 3,818 Likes
2019 C63CS
According to the owner's manual, it's the same procedure as in the 2019. Once you have the service activated, then you need to go to System | Connectivity and choose Set Up Hotspot. I've had mine active for the complementary 30 days, but didn't renew. It was working fine. The main Wi-Fi setting is Wi-Fi in general. If you turn that off, then all the Internet connectivity is deactivated and the COMAND system won't be able to provide traffic data etc. The HERMES LTE module in these cars is essentially a Wi-Fi broadband router, and the COMAND system connects to it via Wi-Fi, so the Wi-Fi option needs to be checked, but the Hotspot is a seperate function that can be enabled or disabled and needs to be configured.
Is it possible because I didn't get the multimedia package I am unable to access the hotspot? I opted out of that because it seemed redundant with standard android auto/apple car play...
2019 C63CS
Ah, that was gonna be my next question. You said your car was fully loaded, so I assumed you had the multimedia package. But yes, that's your problem. W/o multimedia package there is no hotspot among other things. Here's what the connectivity menu looks like with the multimedia package and also the options under the hotspot.
2019 C63CS
I agree with that. One could argue that, by using the vehicle hotspot, you benefit from the improved signal attenuation provided by the vehicle antenna. My argument is that the gains, if any, are nominal. I'm also a systems engineer for what it's worth.
2019 C63CS
Right, the main advantage is that the car's antenna is external, so it doesn't have to fight the inherit faraday cage that the body puts up. Phones inside of the car have to increase their output power somewhat to get out, subjecting the passengers to a stronger signal than outdoors. In areas with a weak signal, the external car antenna may provide a connection, while the phone inside of the car wouldn't get a strong enough signal. I was considering it for an improved connection as I sometimes drive in areas that have a weak signal or barely no signal, but ultimately after the free 1 month trial ran out, it didn't seem to be worth paying for another device on my AT&T plan just for an occasional slightly improved signal. Another use case for it would be if you had an Internet connected dashcam, then it could stay connected to the Internet while the car is parked and alert you if something happens. The built in MB Apps also require the Wi-Fi hotspot to be activated if you want to use them.
Fwiw I do have the digital dash and mb apps. I think they may have broke the packages out differently for 2020s vs 2019... Still unclear what the hell the wifi box is for in the connection settings.
