C450/C43 AMG
Baseline dyno
Old Jun 11, 2020 | 02:01 PM
batman719's Avatar
2019 C43 AMG Coupe
Baseline dyno
JB4 + BCM ordered. Will post follow-up results in a few weeks after install/tuning.
Old Jun 11, 2020 | 02:26 PM
BMS's Avatar
BMS
Former Vendor of MBWorld
2018 C63 Sedan
Looks good! Keep in mind dyno results can vary day to day so be sure to do a couple runs on JB4 map0 (disabled) for same day comparisons.
Old Jun 11, 2020 | 03:12 PM
batman719's Avatar
2019 C43 AMG Coupe
Thanks; will do.
Old Jun 11, 2020 | 08:18 PM
JonWu's Avatar
C43
Originally Posted by batman719
Thanks; will do.
You are doing god's work. Ive been wanting to see this for so long.
Old Jun 11, 2020 | 09:37 PM
batman719's Avatar
2019 C43 AMG Coupe
Glad you find it helpful. That was my motivation for sharing.
Old Jun 11, 2020 | 09:43 PM
Dieseldan9's Avatar
2018 C43 AMG Brilliant Blue Metallic
Not bad for 6k elevation and over 90 degrees
Old Jun 11, 2020 | 10:50 PM
Trekt43's Avatar
C43
You're not the hero BMS needs, you're the hero BMS deserves.
Good luck batman
Old Jun 12, 2020 | 08:42 AM
JonWu's Avatar
C43
It would also be great if you could even take pics of the setup of the JB4 itself so other newbs like myself can see how difficult it is to install
Old Jun 12, 2020 | 08:45 AM
RichardCranium3's Avatar
'16 AMG GTS, '21 AMG GLE53
There are some threads here if you search, as well as detailed install guides on the n54 forum that BMS hosts for install, tuning, and general discussion
Old Jun 12, 2020 | 09:08 AM
TModelle's Avatar
C190
The install guide is on the N54 (C43
Model Specific) Forum. Granted the install instructions aren’t the best. But it takes about 10 mins for the hardware install, and maybe about 10 mins for the software install. Then subsequent removal or install only takes 5 mins once you’re familiar.
Old Jun 12, 2020 | 09:30 AM
batman719's Avatar
2019 C43 AMG Coupe
Sure, I can do that. Hopefully I install it correctly the first time
I found the installation instructions for JB4, but not the BCM. Still looking.
Old Jun 12, 2020 | 02:25 PM
jevsays's Avatar
2016 C450 AMG, 2005 C230 Kompressor
Excited to see the results and I'm sure you'll be glad you went the JB4 route.
For install, I used a combination of Burger's plans and a couple YouTube videos for different angles and helpful tips. Easy install (C450 AMG) for me so I'm sure it won't take you long at all.
Old Jun 23, 2020 | 10:44 AM
batman719's Avatar
2019 C43 AMG Coupe
JB4 installed this past weekend. Currently adapting. Will work on zeroing in with BMS over the next week or so as my schedule allows. Follow-up dyno planned for mid July.
Old Jun 24, 2020 | 11:20 AM
JonWu's Avatar
C43
Did you install BCM as well? Can you comment on how complicated it was to do so correctly?
Old Jun 24, 2020 | 12:08 PM
batman719's Avatar
2019 C43 AMG Coupe
Hi, yes, I installed BCM as well. It was not difficult at all. The BCM portion of the JB4 was already installed into the JB4 unit itself since I ordered them together. If you have a JB4 and then order a BCM separately, you have to connect the BCM to it. From what I understand, this is not difficult.
All I had to do was connect the BCM to the appropriate sensor on the car. This is identical to connecting the MAP1 and MAP3 sensors.
If you need any help, I am happy to provide a picture.
Old Jun 24, 2020 | 01:17 PM
As one of the early BCM adopters and having to do it the "hard way," I can also confirm final install is very simple.
Old Jun 24, 2020 | 04:18 PM
BMS's Avatar
BMS
2018 C63 Sedan
OK if you need any help my email is terry@burgertuning.com
Old Jun 24, 2020 | 04:20 PM
batman719's Avatar
2019 C43 AMG Coupe
You already helped me on Sunday, Terry, but thanks again!
