C450/C43 AMG
Max Lug Bolt Length with 3mm Spacers?
Old Jul 3, 2020 | 06:15 PM
17C43Black's Avatar
2017 C43 Sedan
Hi All,
I’ve got a 2017 C43 sedan, and after searching the forum, can’t seem to find a definitive answer to what the max length of lug bolt will fit (without rubbing) when using 3mm spacers.
I know the stock bolts have a 27mm shank, therefore a 30mm shank would be ideal. Problem is I couldn’t source any, at that length. I eventually found 35mm shanks, and have started to grind them down. Thinking I’d leave a bit more material, say 31 or 32mm if the tolerance front and back would allow.
Anyone know definitely if a 31 or 32mm shank will not be too long?
thanks.
Old Jul 3, 2020 | 06:32 PM
alexasa's Avatar
c
2mm over is fine
Old Jul 3, 2020 | 11:48 PM
17C43Black's Avatar
2017 C43 Sedan
Thanks very much!
