C450/C43 AMG
c450
Old Sep 6, 2020 | 12:46 PM
guillelrd's Avatar
C450
c450
hello good, I'm a Spanish guy and I'm talking to you from the translator sorry, next week I'm going to get a c450 from 2016/01 with all the extras and my question is if the car can be fitted with the c43 parameters of the temperature of the motor oil, the one of the gearbox and all those values ​​that there are. A greeting and in brief I will upload photos !!!
https://www.mbdecoder.com/decode/WDD2052641F328993
Someone who can give me a hand with the subject or knows if I can install it later, I leave the vin
hola buenas,Soy un chico español y os estoy hablando desde el traductor lo siento,La semana que viene me voy a por un c450 de 2016/01 con todos los extras y mi pregunta es si el coche se le puede poner los parametros del c43 de la temperatura de aceite de motor,El de la caja de cambios y todos eso valores que hay.UN saludo y en breves subire fotos!!!
Old Sep 6, 2020 | 01:01 PM
stockbmw's Avatar
2018 C43
Only major difference between c450 and c43 are performance exhaust and 9 speed transmission.
As for oil, both cars use same grade oil.
Old Sep 6, 2020 | 02:07 PM
Ramsino's Avatar
C43
Are there not differences with suspension, AWD ratio, the physical size of the turbos and other things or do you mean just perceivable differences?
Old Sep 6, 2020 | 03:26 PM
guillelrd's Avatar
C450
[QUOTE = stockbmw; 8150892] La única diferencia importante entre el c450 y el c43 es el escape de alto rendimiento y la transmisión de 9 velocidades.
En cuanto al petróleo, los dos coches utilizan el aceite mismo grado. [/ Quote]
I mean the amg menu where you can see the turbo pressure and then the gear oil temperature etc etc
Old Sep 6, 2020 | 05:38 PM
stockbmw's Avatar
2018 C43
Car looks good. Few things caught my attention were performance seats and the car being a wagon made in germany.
As for temperature gauges, it's under steering wheel control drop down to AMG setting and you have all there. Check to see if your C450 aka C43 wagon have it.
There is also another set of temperature gauges under vehicle setting on main dash screen.
Old Sep 6, 2020 | 11:41 PM
BayAreaAMG's Avatar
2016 C450 AMG
The C450 didn't have the AMG menu, if you have it enabled it will show you oil temperatures but not that boost gauge.. that's about it. Most of all the menus don't work but you can still get to it. I had mine enabled by purchasing an OBD device to reprogram it automatically. Got it on ebay for like $150 by someone who makes them.
Old Sep 7, 2020 | 09:13 AM
guillelrd's Avatar
C450
I have seen that some c450s on the central screen of the browser show the torque and power, hopefully mine brings it or can enable it, Greetings
Old Sep 7, 2020 | 09:14 AM
guillelrd's Avatar
C450
[QUOTE = BayAreaAMG; 8151258] El C450 no tenía el menú AMG, si lo tiene habilitado le muestra las temperaturas del aceite pero no ese indicador de impulso ... eso es todo. La mayoría de los menús no funcionan, pero aún pueden acceder a ellos. Tenía el mío habilitado comprando un dispositivo OBD para reprogramarlo automáticamente. Lo tengo en ebay para como $ 150 hacia alguien que les hace. [/ Quote]
Could you pass the link to me privately?
Old Sep 8, 2020 | 05:48 AM
gpouliniii's Avatar
C450 AMG
I have the 2016 C450 and “gauges” screen is only available if the car has COMAND installed from the factory. I’m not very happy that mine doesn’t have it. Gonna get the Android screen soon. It had apple/car play.
Old Nov 6, 2020 | 04:32 AM
mokawop's Avatar
c450
Hi, do you happen to still remember who its from? I have been wanting to get the amg screen on the center dash but dealer said if its even possible it will be 1600+. And by the amg screen, you mean the one with boost gauges and everything right?
Old Nov 6, 2020 | 11:34 AM
BayAreaAMG's Avatar
2016 C450 AMG
I can send you a link to activate the AMG menu that appears on the instrument cluster only. That's different than the menu on the radio screen where it shows the horsepower. To get that one you do need to upgrade the entire radio and screen, and get it reprogrammed.
Old Nov 8, 2020 | 05:10 PM
guillelrd's Avatar
C450
[QUOTE = BayAreaAMG; 8196522] Puedo enviarle un enlace para activar el menú AMG que aparece solo en el grupo de instrumentos. Eso es diferente al menú en la pantalla de la radio donde muestra la potencia. Para conseguir que uno lo hace necesidad de actualizar toda la radio y la pantalla, y conseguir que reprogramarse. [/ Quote]
If what I want is the one that appears in the instrument panel the amg menu, and I would like to see if I can put it
Old Nov 9, 2020 | 03:22 AM
BayAreaAMG's Avatar
2016 C450 AMG
PM'd
Old Nov 9, 2020 | 03:36 AM
gpouliniii's Avatar
C450 AMG
Originally Posted by BayAreaAMG
PM'd
Can you PM that to me as well please? Thanks I’m advance!
