Rear camber
I have a 2016 c450 AMG and have lowered it on H&R sedan lowering springs. Since then I have gone through a set of tires because I didn’t get an alignment. After replacing the tires to Pirelli P7 225/45/18(front) 245/40/18(rear) I went to get an alignment and the tech was only able to adjust the front as rear had no camber adjustment left.
To prevent buying ANOTHER set of tires is there a aftermarket rear camber adjustment I can purchase to have the rear alignment done properly?
All information would be greatly appreciated!
I installed their front and rear kits on my previous c43 to get back to factory alignment specs after lowering. There's other options as well but I can't remember the company names...
do you have part numbers? I just need for the rear as the front had no issues during alignment.
Would you recommend both front and rear since all four corners are lowered? Will a alignment be necessary again after installation?
Here's what my old c43 looked like with the front and rear bushings... lowered and back to factory alignment specs
when lowering the camber increases significantly and many owners report the inner shoulders wearing prematurely as a result.
do you have spacers installed with this setup?
I know MB spec on the 450 has negative camber.. same for the 43?
Driving the car today I noticed the car was pulling a little to the left when the steering was straight. Went back to the alignment shop after work and he corrected the front. I again asked about the rear and he said he corrected TOE but no camber adjustment left.
He recommend a camber adjustment arm. Is this an alternative setup as to the KMAC bushing setup?
lets just say the alignment in the front is fine. All he was able to adjust in the rear for alignment was the toe. He said there was 3 degree camber.
does anyone have MB spec for alignment? Will the alignment be able to get to MB spec once lowered?
This is what I did with mine. I’m lowered on h&r sport springs in the rear but, I have h&r VTF springs up front. I won’t go in too deep on that unless you really wanna find out why. Anyways, back to your concern. The rear control arm has an elongated hole which locks the bolt in place with a notch. You can grind the notch down so it allows the rear lower control arm to be pulled inwards. You’ll be able to get it close to spec with all parameters within MB spec tolerance. The fronts though, will still be out of camber spec... but, toe will be good and still tolerable because you steer the wheels anyways.
If I had $1,000 to spare plus labor to install, I’ll get those k-Mac in a heartbeat! But, for now it’s been fine and I’ve had the lower control arms pulled for 4 years...
Granted that I only have 11k mi. on my ’17 C43 and have switched tire and wheel setups 2x, I’m totally fine with it being this way.
This shows you the notch which you need grind.
These were my alignment specs when I still had h&r sport springs f/r.
This is my most current spec after I had h&r VTF springs installed up front and kept the sport springs in the rear.
This is as close as we could get to MB spec on my setup.
https://modalwork.com/collections/c4...ar-camber-arms
did you happen to resolve this and mind if you could share what route you went to fix your camber?
Hey! did you end up fixing your rear negative camber? Im having the same issue and having no lead where to start, have no idea what these 'kmac bushings' do or how they work
When it comes to resolving costly, premature edge tire wear we manufacture a TOTAL SYSTEM.
Currently OEM there is only Front and Rear Toe "directional" adjustment.
Can adjust Toe all you want and it is not going to resolve uneven tire wear - example excess right hand side edge wear brought about through high cambered roads (all align tech can state is "have adjusted Toe within factory specs" - but the uneven wear still persists).
Camber adjustment is essential "ALLOW TO ADJUST TIRE CONTACT ANGLES - SPREAD LOAD MORE EVENLY).
C450 / C43 AMG:
FRONT CAMBER KIT #503416-1G $345 (Both Sides)
Less cost then one Hi-performance tire.
REAR CAMBER (and Extra Toe) #502226K $480
Both above kits simply replace the lower arm inner bushings. Can fit without need for arm removal.
KMAC unique patented design allows precise single wrench adjustment. Accurately (under load) direct on alignment rack FIXING IT RIGHT THE 1ST. TIME.
Best Regards, Kevin
See Spoiler Re Complete Range Adjuster Kits for C450/C43 AMG
AUDI to VOLVO - KMAC Experience Of Resolving OEM Suspension Shortcomings Since 1964!
