C450/C43 AMG
Jb4 map6
Old Jan 26, 2021 | 09:15 AM
Kevin Diao's Avatar
c450 amg
Jb4 map6
Hey guys anyone running map 6 on c450s? if so what boost setting, mods, and gas do u guys use.
Old Jan 26, 2021 | 09:37 AM
MatthewJ's Avatar
'15 C400 and '15 ML350
Lots of people running map 6 on the C400 and 450 since the stock boost levels are less than the C43 19+ cars.
Start with a maps 3-5 and see if the car is ok with that boost for your fuel and altitude before changing to map 6 custom. For me i was able to start with map 5 as baseline for map 6 and work from there. But with a C400 the stock boost is like 2psi less than the 450 so you might be close to limit with map 5. Really just depends on where you live, the fuel you have to work with and the other mods.
Just log a long pull (40-100) to see how the car is behaving with the map changes. Let the car learn the trims a few miles between map and fuel changes.
Old Jan 27, 2021 | 04:14 AM
Kevin Diao's Avatar
c450 amg
Fuel
gotcha, I live in California what do you think the best fuel option is and what kind of a mix should I run in order to run map 3-5
