C450/C43 AMG
Vossen Hf-5 fitment advice
Old May 31, 2021 | 05:34 PM
Doogie999's Avatar
C43 Amg
Hi All does anyone have Vossen HF-5 in 19" on there C43? I am going to purchase the 19X8.5 offset30 and 19X9.5 offset 45. I am currently on OEM 19X7.5 offset 33 & 19X8 offset 52 with 12mm spacer in front and 15mm in back. The seller is saying that I dont need any spacers for the vossen 19" is that correct? Also am I able to put my oem tires on the vossen wheels 225/40/19 and 255/35/19? Thanks for your help..
2019 C43
Old May 31, 2021 | 05:59 PM
gabemcclintock's Avatar
2019 C43 AMG
One thing that may happen is tire stretch. It is one of the reasons I went with the BBS CI-R rims as they came in a little "thinner" size (19x8 and 19x9) so that I could still use my OEM rubber without the bubbled sidewall.
Saying that I am looking to sell my CI-R's as I really want buy a set of the HF-5's in Satin Bronze
Old Dec 8, 2021 | 06:27 PM
TwiztedAMG's Avatar
2017 C43 AMG
Do you need to run spacers on your front CI-Rs? Actually looking at purchasing your exact setup in black.
Anything I need to worry about with them or do you just like the look of HF-5s better? Just trying to get away from the brittle stock wheels...
Old Dec 8, 2021 | 10:09 PM
BayAreaAMG's Avatar
2016 C450 AMG
I'm pretty sure you need front spacers and hubcentric rings for these wheels to fit. Not ideal as they're not exactly lightweight wheels either.
