C450/C43 AMG
Bms intake?
Old Jun 2, 2021 | 02:22 AM
JonathanJoestar's Avatar
2018 C43 AMG
Bms intake?
Hi guys new member here, I've had the c43 for 3 weeks now, The car has a stage 2 tune, full exhaust system, and k&n filter installed. Currently i am planning on getting an intake for my c43. Does anybody have experience using the bms intake? Previous owner has a mst performance intake installed on the car but was taken off almost immediately since he said it caused huge loss of power in high speed. Any info would be appreciated thanks!
Old Jun 2, 2021 | 06:12 AM
djprov431's Avatar
2021 C63S Coupe
Looks sharp!
Old Jun 2, 2021 | 08:27 AM
Egghaus's Avatar
2018 C43 Sedan
Sorry this is off-topic but what front lip is that? Is it the OEM one, it looks great.
Old Jun 2, 2021 | 11:39 AM
paj's Avatar
paj
17 C43 AMG
Wow really bad ***! Love it! I replaced my MST with BMS. If you look close, I kept the MST heat box bottom lol! I like it and you can definitely hear it.
Old Jun 3, 2021 | 01:02 PM
LogosMotorworks's Avatar
Former Vendor of MBWorld
S5,C450
@JonathanJoestar One of the main reasons for the power loss is because the filters sit right on top of the hottest part of the engine (the turbos) so at speed when the engine is working its hardest and emitting the most heat, the intakes are sucking in that hot radiating air. We are coming out with an air intake that sits in front of the engine bay and will be sealed up against the hood...away from the turbos.
This will suck air from the the coolest part of the car (the front).
shoot us an email at logosengineering@yahoo.com and we will forward you prototype pictures!
Old Jun 4, 2021 | 12:58 AM
gpouliniii's Avatar
C450 AMG
He must of had the old MST before they redesigned it, because mine is much faster at high speeds and I’ve had both intakes. Sounds (IMO) and runs (0-100 was better all 5 times) better with the MTS. Less heat soak
Old Jun 4, 2021 | 02:07 AM
Gazwould's Avatar
S204 C250 CDI Sport
Old Jun 5, 2021 | 01:48 AM
Freder8d's Avatar
2017 AMG C43
WRONG! At speed you are not sucking up hot air as there is this thing and it's called airflow! I get it your trying to promote your product, but don't put down false information.
Old Jul 19, 2021 | 11:06 PM
Rnat's Avatar
2018 AMG C43
MST Air Intake install
Hey guys new to the site. I just installed the v2 of the MST air intake on my 2018 C43. Made sure the negative cable was removed when I installed them, after install took it for a drive and my car was not pushing more then 150hp and 200 torque.
also the boost was showing wide open even if the car was stopped. Check engine light came on after a few miles with codes P1189 and P1191. Once that happened put everything back reset the CEL and installed my old original intake and car runs fine again. I find this sort of impossible to mess up the install since it's literally a few pieces.
Have you guys ever experienced anything like thjs?
Old Mar 23, 2025 | 07:08 AM
Aaron Ramsey's Avatar
2018 AMG C43 Sedan
How much red oil do you use when you clean these filters?
Hey! I have the same BMS setup but it has come time for cleaning the filters. I have the S&P cleaning kit but I cannot find anywhere that says how much oil to use.
Old Mar 27, 2025 | 10:27 AM
Ken Miles's Avatar
Mercedes C450 DTM Team Edition
Hello!
Can you tell me what the front bumper splitter is called?
Is there a manufacturer name?
