C450/C43 AMG
Wheel Nut Lock
Old Jun 17, 2021 | 09:49 PM
PeteC43's Avatar
C43 W205
Wheel Nut Lock
Apologies if this falls into the silly thread category. I've searched everywhere for the answer and cant find it.
I have a 2016 C43 with standard 19 inch wheels. I'm taking it to the tyre shop tomorrow to have a slow puncture fixed, plus to have all the wheels balanced as it has an annoying vibration.
Do the wheel nuts need s special nut adaptor to remove, or are they standard nuts ? I couldn't find anything in the boot or glovebox that might indicate it needs a special adaptor for the nuts
Old Jun 17, 2021 | 10:40 PM
W205C43PFL's Avatar
Check to see if your lug nuts on all wheels are the same, if you notice any lock like pattern then you car has wheel locks installed. If it doesn't, chances are your car didn't come with wheel locks. Depending on where you live, some cars have optional wheel locks and if your car didn't come with wheel locks (as in you didn't option them), then the wheel lock key won't be included hence why you don't see it.
Old Jun 18, 2021 | 08:25 AM
Hungalow's Avatar
C43 2017
Mine came in a small plastic box with 4 spare lugs and the locknut in the center. It was under spare tire and basket.
Old Jun 18, 2021 | 02:29 PM
Loibs's Avatar
2020 C43 AMG Coupe
Are you sure that these are spare lugs and not the lock kit with key?
Old Jun 19, 2021 | 12:07 AM
PeteC43's Avatar
C43 W205
Well i found that they were just standard nuts. What i did find when i went to the tyre shop to fix a slow leak was that the leak was caused by a cracked wheel.
Thanks, Mercedes Benz Sydney. So much for your 100 point pre sale inspection
Old Jun 20, 2021 | 08:10 AM
Hungalow's Avatar
C43 2017
those are the four original bolts removed and replaced with the lock nuts....with key lug in the center Also becomes your new car bonus...4 extra bolts incase Manny at your tire shop strips one... mercedes you so genny.
