Worn out power lock button
So I’ve seen where you can buy the entire power lock switch from Mercedes. It’s surprisingly really cheap, but you have to remove the door panel, which is a pain with all those electronic connectors and attached. I also see replacement buttons for like $15-$20. They appear to leave the actual power lock switch intact, and only replace the button covers themselves. Has anyone used these? If so, how did you remove the old buttons?
If it were me, I would tell the dealer that the attempt at repair was sub-standard from what you'd expect from Mercedes, that they made the issue worse-looking by virtue of the laughingly cheap attempt at fixing it, and insist that they replace it with a new button.
On my previous C43, a technician accidentally got some kind of brake grease on my steering column assembly. I couldn't remove it with water or any type of plastic/leather cleaner. They attempted to remove the stain with isopropyl alcohol and it made it look worse, and it dripped on some black plastic and "bleached" the wheel.
I had them replace my entire steering wheel and column - a $2,500+ repair - under warranty. My car was obviously new, and still under warranty.
