New spacers making squeaking sound
So I installed spacers about a month ago 15 in the fron and 20 in the back on my oem 19” rims for my 2017 c43. And recently I’ve noticed a squeaking sound when I’m at low speeds like in parking lots or going into my garage on my driveway. It wasn’t there when I had them installed I even went on a drive to see for squeaking and any sounds nothing. But now it’s there and it’s annoying, not sure if I should be worried, can anyone help me out?
First, the supplied longer bolts need to be r14 radius shouldered for stock Mercedes wheels. There are r12 and r13 radius bolt heads as well, and using these would cause noise like you deceived. Unfortunately, unless you have a radius gauge it is very hard to tell what they gave you. Most of the time suppliers give you r14 which are used for Audi.
Second, especially if your spacers are in the 12mm to 13mm range (and even some brands of 15mm spacer) as sometimes they do not have enough bore depth on the mounting side to accommodate the hub protrusion in the center of the hub of the car. What happens is you tighten down the wheel and the center piece breaks off inside because there’s not enough provision. Remove your wheel and look at the spacer. It’s more common than you would believe, breaking the spacer’s center when torquing down the wheel because it’s just not suited to your application.
Stockw205 (07-28-2021)
Well actually they gave me the wrong bolts which like you said are the r13 so I had to go through the hassle of finding the r14 head to better fit. So I don’t think it’s the bolt since it’s the correct size. But it may have cracked when torquing down, something I never considered. I’ll have them removed at looked at as soon as possible.
I hope their not cracked, and as for now until I can get to my wheel/tire guy I think I should be good to drive on it until I find some time to go have it looked at.
Present: 2019 C43 Estate
I'd honestly be shocked if the "squeaking noice" is from your spacers. Especially if they'd been fine up till now. If they've been torqued down since install, there's not much that can shift after the fact. If there was a problem with install, you would likely have noticed it right away.
How are your brake pads? Have you done any suspension work to your car?
