C450/C43 AMG
C43 weak 0-60mph
Old Nov 17, 2021 | 10:59 AM
caza's Avatar
C43 amg
C43 weak 0-60mph
Hi my C43 (2019) is lacking power, my 0-60 runs are constantly around 5.2secs which is weaker than anything I’ve seen and I can feel that the 30-60 is where the power is lacking. I know it because I’ve been driving C43s since 2017. The 0-30 is fine.
I get this time even when launching with foot on the brake and with the car empty.
I have an appointment soon for a transmission check (gear 2 and 4 having issues) what else can I point out to maybe fix this issue?
My tires are almost brand new, contisportcontact 5 SSR.
Old Nov 17, 2021 | 11:37 AM
W205C43PFL's Avatar
Sounds familiar:
https://mbworld.org/forums/c450-c43-...-no-codes.html
Old Nov 17, 2021 | 11:56 AM
caza's Avatar
C43 amg
Interesting, I’ll need to check later if my hp drops like him.
Old Nov 17, 2021 | 04:23 PM
W205C43PFL's Avatar
Keep us updated.
Old Nov 17, 2021 | 08:17 PM
C43HeartBoost's Avatar
C43
I assume you logged this time with a reputable performance tracker, once the car was fully warmed up (all AMG gauges showing white), in Individual mode with all settings in Sport+ besides suspension set to “comfort”, with brake boosting to 2k to 2.2k. Assuming so, I agree the times are lackluster. If not, repeat using these instructions.
Old Nov 20, 2021 | 10:46 PM
caza's Avatar
C43 amg
Keep us updated.
I tried a couple times and I had no problems reaching 380-385hp, the only thing it was maybe a little slow to reach max hp.
Old Nov 20, 2021 | 10:50 PM
W205C43PFL's Avatar
I see thanks for the update at least now we know your battery is good.
Old Nov 20, 2021 | 10:55 PM
W205C43PFL's Avatar
How about boost pressure? Were you able to check that? Are you suspecting the transmission issues you mentioned the direct cause to the sluggish performance?
Old Nov 20, 2021 | 11:50 PM
caza's Avatar
C43 amg
actually my battery is always showing as “partially charged” in mercedes me app and I had a couple time a message saying that battery level is critical after letting the car on for around 30mins
Old Nov 20, 2021 | 11:55 PM
caza's Avatar
C43 amg
Boost goes all the way up.
My transmission sometimes fail to shift from 1 to 2 in time. It reaches the good rpm then I feel like the car isn’t accelerating for fraction of a second then shifts to the 2 and giving a hard hit, also the loud bang that usually happens from the exhaust doesn’t happen at all.
But that a rare case and when it shifts perfectly I still get the same time so
Old Nov 21, 2021 | 09:41 AM
W205C43PFL's Avatar
What is the voltage when fully charged and what is the voltage when engine is off?
Old Nov 21, 2021 | 09:42 AM
W205C43PFL's Avatar
Yup that transmission behaviour doesn't sound normal at all (despite the C43 having a quirky transmission) . Does the transmission slip at all?
