C450/C43 AMG
2019 c43 opf remove
Old Dec 27, 2021 | 04:11 PM
energie80's Avatar
c43
2019 c43 opf remove
Hello, im a new c43 2019 owner and im looking to remove the opf on the mid.
Do i need to remap the ecu? someone said me no cel errors or limp mode but the mechanic waring me.
Any helo?
thanks
Old Dec 27, 2021 | 04:53 PM
superswiss's Avatar
2019 C63CS
My understanding is that you can't just remove the OPF. There are sensors before and after that measure exhaust flow to determine when the OPF is full and a burn cycle needs to be triggered, so the ECU has support for all that. If you remove it, it will mostly likely trigger issues.
Old Dec 27, 2021 | 04:59 PM
energie80's Avatar
c43
well someone said the sensors are just to sign if the opf are blocked or not
Old Dec 27, 2021 | 05:11 PM
superswiss's Avatar
2019 C63CS
Effectively yes, but pretty sure the ECU will complain if they are missing, or if they are left in place they may report an improbable measurement as they are expecting a certain reduction in exhaust flow from the OPF, which if missing, the flow would be higher than expected and they may report an OPF malfunction. Normally, the particulate filters clear themselves if the exhaust gets hot enough, for example with lots of highway driving. This is called passive regeneration, but if the exhaust never gets hot enough for example due to frequent short distance driving, then it can fill up and an active burn off needs to be triggered. So the sensors are there to detect this and let the ECU know that it needs to artificially increase the exhaust temperature, but they are also there to make sure the OPF works as designed.
Old Dec 27, 2021 | 05:13 PM
energie80's Avatar
c43
Need to find someone who removed them 😅
Old Dec 27, 2021 | 05:15 PM
superswiss's Avatar
2019 C63CS
Probably, but not many members here that might be able to help you. The majority of members are from the USA here, and US spec models don't have the OPF. They have secondary cats as before.
