Help! Test to See if your C43 Does This (Buckling after downshift to first gear)
Here's how to re-create:
- Set to Sport+ mode, automatic (not manual/paddle mode)
- Set main display so you can see when the vehicle changes gears
- Drive the car up to 2nd or 3rd gear, then let it slow down so it shifts from 2nd to first
- The instant you see the car shift from second to first gear apply the gas as if you were accelerating after making a turn
My car is under warranty, I took it to the dealer and they said the transmission comes back with no error codes, so "nothing to fix." Ran a search and the closest I could find was this https://mbworld.org/forums/c-class-w...ift-issue.html but it's actually a different issue.
Anyone testing this and reporting back would help me to figure out if I need to open a case with MB or if every C43 is like this.
THANK YOU!!
What do you think, same thing?
THANK YOU!!
No it isn't. The C63 is. The C43 has a torque converter, but with an aggressively tuned lockup clutch.
