Importance of diameter for competition tires
Front https://www.discounttiredirect.com/b...-r888r/p/40831 25.39"
Rear https://www.discounttiredirect.com/b...-r888r/p/40828 25.31"
I assume nobody goes with a square setup with, for example, 8.5" wide wheels on all 4 corners? I know the offsets would be different, but the tires would be the same.
Thanks for your input.
within 3% is the go to for diameter. 235/45/18 would be closer but adds rotational mass and roll over - which, without proper suspension modification is a moot point I guess. K3's with stiffening braces would be at the top of my list. Even then you'll be wanting more. It's a big heavy car that wallows in turns.
Within 3% difference between front and rear? Or, within 3% of stock 26.0" diameter? My example R888R's are nearly identical front and rear, but are near the 3% limit from stock of 25.22".
Well, I know it's not a 911 or Elise. And I'm no pro, so the car has better skills/limits than me. I'm just getting started. I'm thinking wheels & tires this year. Maybe brakes next year. Suspension would be after that, eventually (biggest cost). This is my daily driver that I just got last week, so the wallet is a bit light and I'm only planning a few events this year. I get more vacation days next year!!
