2020 c43 with 22k miles. Needs brake job already?
My 2020 c43 lighting up for brake service. I always drive with TCS off. No cruise control. Is that normal?
Update: Went to a trusted independent. They said fronts look good. Rear driver side worn but still good. Rear passenger worn much more. Anyone know why just 1 Rear side would be bad?
if the rotors are still in spec then just change the pads and sensor and maintenance the caliper. Shop will probably want to replace whole axle pads and rotors though to prevent return customer.
He just said i can't replace the pads without doing rotors.
I'll go to dealer and see what they sat.
Strongly suggest finding a trusted independent shop in your area or doing it yourself. My local shop did it for around $700.
