C450/C43 AMG
Widest tires on Stance SF07 rims?
Old Feb 28, 2023 | 01:27 PM
DirtyDD's Avatar
C43 AMG W205
Question Widest tires on Stance SF07 rims?
Folks,
I'm getting a set of Stance SF07 19x8.5 ET32 and 19x9.5 ET45 on my 2017 C43 sedan. These rims are an inch wider than stock. What tire sizes are folks running on these wheels please?
Options:
1. Max'd out, and want to know if they will rub... Anyone running anything this wide?
- OEM Fronts 225/40/19 line up closely (0.2%) with 255/35/19 in terms of circumference.
- OEM Rears 255/35/19 line up closely (0.2%) with 295/30/19 in terms of circumference.
2. Slightly narrower than that, circumference just slightly lower than OEM
- 245/35/19 circumference error just over -1%
- 285/30/19 circumference error just over -1%
3. Narrower still on rear, per a recommendation in a previous post on here...
- 275/30/19 circumference error just over -2%
4. Very safe option. Not much wider than stock with same sidewall ratio. I.e. slightly taller and larger circumference
- 235/40/19 circumference error +1%
-265/35/19 circumference error +1%
Old Feb 28, 2023 | 03:44 PM
alexasa's Avatar
c
are you lowered? do you have power mods?
if no is the answer to both of these questions then you should run option 4 - aka tried and true set that can put all the power down without any downsides.
You really need to go with a 20 inch wheel to have better wider tire sizes.
