C450/C43 AMG
9G-TRONIC 725.0 Shift Issue
Old Mar 12, 2023 | 11:49 AM
Driver2's Avatar
CLE53
Question 9G-TRONIC 725.0 Shift Issue
I recently had the valve body replaced (under warrantee) because the transmission was sharply upshifting from 4th to 5th when coasting and the trans finally tripped a code.
The problem is unresolved and all shifts are now not as crisp as they were when the car was new. But, before I make this an issue with the dealership I'd like to know if this behavior is "normal".
The Invoice says that the valve body is for a 725.0 / 725.1 trans. I don't know if this is significant.
My sense is that this may be a quirk of the trans that has been masked by softening all of the shifts.
The work-around is to just use manual mode to hold 4th. But I miss the snappier shifts...
Old Mar 12, 2025 | 08:51 AM
W205C43PFL's Avatar
Might need time to adapt again.
Old Mar 12, 2025 | 08:53 AM
W205C43PFL's Avatar
Oops didn't check time of post.
