Help! Rubbing with 20s
I have 20s front and rear on my 2019 c43. I’m running 285 rear and 245 front. I’m lowered on H&R sport springs as well. Ever since I left the wheel shop, I’ve been rubbing hard on my driver side and I’m slowly screwing my car up. I NEED recommendations to what to do! It’s like the car is heavier on my side and is lower. My passenger rarely rubs. So what should I do?!? The difference in height is clearly visible in the photos I think.
Thank you in advance.
Driver side.
Fender is being beat.
Vs Passenger side.
Here are a couple of good offset calculators. The second one visualizes the difference in case you have trouble with the abstract numbers. Going to an offset of 30 will move your wheel in by 2 mm. Going to 32 will move it in 4 mm. Now the inner clearance will reduce by the same amount, so at some point it may rub against the strut since your aftermarket wheel is wider than stock. My bad, too, I should have said you have too little offset, not too much.
https://www.1010tires.com/Tools/Whee...et-Calculator#
https://tiresize.com/wheel-offset-calculator/
https://www.carthrottle.com/post/wha...-it-important/
