C450/C43 AMG
C43 Crankshaft position sensor location?
Old Jun 12, 2023 | 12:49 AM
C43Fail's Avatar
C43
Question C43 Crankshaft position sensor location?
I circled in yellow where I believe it to be. Is this correct?
Old Jun 12, 2023 | 08:49 AM
Cosworth2000's Avatar
2022 E53 AMG
Our engines have 2 cam sensors and they are both at the top of the engine on the left and right site.
Old Jun 12, 2023 | 01:47 PM
MatthewJ's Avatar
'15 C400 and '15 ML350
Camshaft sensor and Crankshaft sensor are not the same. OP is asking about crank sensor, which is usually at the front of the engine behind the main crank pulley. That sensor in yellow looks like a temp sensor that close to a coolant pipe connection. (I admit tho, i dont recall any coolant lines running to rear driver side of the motor like that.)
Old Jun 12, 2023 | 01:51 PM
C43Fail's Avatar
C43
Yeah, my crankshaft sensor comes in tomorrow and wanted to proactively remove it, but I can't find it anywhere. Found a service manual for the M276 engine, but it doesn't show explicitly where it's mounted on the engine. When I check parts catalogs, the Sensor is just hovering in the air with a very vague line pointing to where it goes.
Old Jun 12, 2023 | 03:04 PM
jonathan358's Avatar
2018 Mercedes C43 AMG Coupe
Yes, that is the CPS.
Old Jun 12, 2023 | 03:20 PM
chassis's Avatar
2017 GLE350 4MATIC
Two false posts #2 and #3 above, sadly.
MB standard crank position sensor location is 11 o’clock as viewed from the driver’s seat, at the junction between engine block and transmission housing. Circled in yellow above.
Old Jun 12, 2023 | 06:29 PM
C43Fail's Avatar
C43
Thanks, that's going to be fun to get to, lol. At least I know where it is now.
Old Jun 12, 2023 | 11:15 PM
2022 E53 AMG
Shoot, I messed up on the reading and thanks for correcting what I said in error.
Old Jun 13, 2023 | 06:28 AM
MatthewJ's Avatar
Thanks chassis for clearing it up.
Old Jun 13, 2023 | 10:56 AM
2022 E53 AMG
You going to do the work yourself?
Old Jun 13, 2023 | 12:34 PM
C43Fail's Avatar
C43
Yeah, I really struggled just locating the damn sensor yesterday, but finally found it. Had to move some wire mounts out of the way, then squeeze my hand alllll the way down there and took about 10 minutes to get the sensor unclipped. I only have regular torx wrenches which will make it impossible to unscrew the hidden torx bolt, so I ordered a flex extension off Amazon and some torx sockets. Should arrive tomorrow.
It's completely inaccessible from the bottom unless you have very skinny arms and hands, so will be working from the top while laying on some pads.
Old Jun 13, 2023 | 05:00 PM
chassis's Avatar
2017 GLE350 4MATIC
W204 video but will give you a general idea of the project.
Old Apr 21, 2026 | 07:43 AM
W205C43PFL's Avatar
Nevermind
Old Apr 21, 2026 | 10:17 PM
atomek's Avatar
2020 AMG C 43
I think this is it... Just in case you need it.
Old Apr 22, 2026 | 08:17 AM
W205C43PFL's Avatar
Thanks for the WIS doc, I was looking for camshaft which makes sense it is on top of the engine near the cam magnets. My bad, made a mistake. Still appreciate your help.
