Upgrades?
I have my doubts about the effectiveness of the upgraded intercoolers currently out. Yes, they're bigger, but they don't change the fluid cooling ability of the current loop, so they probably do very little to drop charge temps over stock.
If you didn't already know, the fluid that goes through the intercooler to cool charge pipe air is also used to cool the transmission.
My .02, separate the cooling loop of the IC from the trans, and get a bigger IC radiator and a better IC pump.
Also, since you have uprated turbos, should your charge air temps go down? The whole point of uprated turbos is to move more air at a given pressure (which should also lower temps since the compressor is in a more efficient part of its efficiency band at higher airflow).
