full E85 capable fuel system?
The only station around me has pretty good E85, regularly tests about 85%
I have a complete set of used injectors, fuel rails, and LPFP on hand, about to send them out and get them all upgraded/rebuilt and then put the Spool HPFP in there too, but just wondering, has this actually been completed by anyone else?
what were the results? a search in this forum for "E85" yielded little.
I ran full e85 however was only tuned for e60 in case the e85 ever tested lower. i ran spool HPFP, Infinite Autowerks Plug and play LPFP, and Infinite Autowerks Upgraded fuel rail. Stock injectors. From the logs they had enough duty cycle left for power we were making. if you upgraded turbos, you may need larger injectors.
I got a set of low mileage injectors off of eBay that I'm going to have rebuilt and flow matched, they'll go in the same time as the infinite autoworks PnP LPFP and bored out fuel rail.
